Terix Terix is offline
Car: 2013 BMW 335i
Default Pure Stage 2 Map 6 Settings - 02-14-2020, 11:38 AM
I'm picking up my car today from a shop who just installed my PS2 turbo. I'm wondering what would be a good starting point for map 6 settings with my mods. I looked at the N55 larger turbo sticky, but some of those settings are with port injection, ethanol, etc. I'll be running 93 pump gas for now.
My mods are as follows:
BMS air intake
BMS 7.5" FMIC
VRSF down pips
BMS WMI kit (usually running 100% meth)
N20 TMAP sensor
PS2 turbo (with DV and inlet upgrades)
NGK 2-step colder spark plugs (from BMS)
I'll get some logs later and post them in the support section, I just need a baseline to start with. I'll probably run map 5 until I know what settings I should use for map 6.
Default 02-14-2020, 12:12 PM
Start with map 1, post the log and make sure everything good and working properly before moving to map 6.
Car: 2013 BMW 335i
Default 02-14-2020, 02:30 PM
Thanks, I'll get some this weekend and post them in the support section.
