Terix Terix is offline
Car: 2013 BMW 335i
Default WMI no flow at WOT - 04-01-2018, 09:39 AM
I have a 2013 335i with JB4, BMS intake, VRSF charge pipe, and VRSF down pipe. I installed the WMI kit yesterday and was able to prime/purge the line just fine, but at WOT I get a reading of 0 which I know is supposed to mean electrical issues. I double checked all connections today, even restripped and connected all wires again, checked pins 3 and 16, and purged the system once again. Everything is 100% correct, yet still I get a reading of 0 and no flow at WOT.
Signal scaling is set to 60 and boost additive is set to 40. Activation PSI is at 12.
I need some help as I have no clue why the system isn't working.
Default 04-01-2018, 09:42 AM
JB4 log? Maybe you have a setting wrong disabling it.
Car: 2013 BMW 335i
Default 04-01-2018, 09:44 AM
Let me get the computer hooked up and I'll post one. Thanks for the crazy fast response.
Car: 2013 BMW 335i
Default 04-01-2018, 10:05 AM
Attached a log. Did a couple WOT pulls.
Default 04-01-2018, 10:09 AM
On the WMI page uncheck all the E85 options, and make sure external trigger min RPM is set to 2000rpm. I'd also set min boost to 9psi.
Car: 2013 BMW 335i
Default 04-01-2018, 10:14 AM
Does external triggers need to be set to 1 for the min rpm to work?
Car: 2013 BMW 335i
Default 04-01-2018, 10:25 AM
Still showing 0 at WOT.
Car: 2013 BMW 335i
Default 04-01-2018, 11:05 AM
Nevermind, missed an ethanol setting. Everything is working now! Thanks for the help Terry!
Default 04-01-2018, 04:30 PM
Easy fix.
