nguyenvn nguyenvn is offline
Car: 2007 335i E92
Default Group Dyno Results - 11-09-2013, 05:00 PM
We did a group dyno today here in Charleston, SC. Just wanted to share the results.
Dyno: Mustang
Temp: 65-70
Here are my logs and dyno results. I didn't get to log the first one b/c it was the test run and my best one unfortunately. I'm guessing Dynojet numbers would have been around 7-10% higher?
2007 335i e92, FBO, E85 AT Flash and Alpina Flash, Fuel e45-50, 100% meth
1st run Map 7 - 424/472
2nd run Map 7 - 412/463 lower b/c too aggressive?
3rd run Map 3, 65 additive - 415/477
4th run Map 3, same - 416/462
Other car results, estimated. Going from memory.
2007 335i E92 MT, FBO minus FMIC, 93+Meth (50/50 Mix) 401/420
His baseline was on Map 4 was 305/300 I believe
2011 335is E92 DCT, 45% E85/93 mix, Jb4+DCI 394/440
Map 4 baseline 299/315
I can't remember what the 335xi put down. It was a n55 with BMW performance exhaust and flash. I think it was around 260/280.
|2007 E92 SGM 335i|
Cobbv3 BMS DCI & OCC VRSF *** & FMIC E85 Custom Backend & Alpina TCU flash ER CP RB PCV+Cap
Walbro 255 Rohana RC5 19s Nittos 555 245/275 Cyba Scoops LUX V3 M3 Cowl ST Coils LCI Tails
Jgnp15333's Avatar
Jgnp15333 Jgnp15333 is offline
Car: 2008 335xi
Default 11-09-2013, 09:37 PM
Your IATs are a thing of beauty.
It's estimated that Mustangs usually read .95 of actual - dynojets read 1.05. (It's the formula that Virtual Dyno goes by anyways)
Mustang - 424whp/472wtq
Actual - 446whp/497wtq
Dynojet - 468whp/522wtq
Let's calculate in a conservative 10% drivertrain loss to estimate your crank HP/TQ.
Mustang - 471bhp/524btq
Actual - 496bhp/552btq
Dynojet - 520bhp/580btq
Next time you you get someone bragging about their vehicles crank Hp as estimated from the factory, you can safely tell them to suck it.
______________________________________
Back after about 5 years of just dailying this with FBO and meth! Prepping to make some big installs and acquaint myself with all of the new tech on this platform.
1/4m - 11.7741s @118.27mph - - - 437awhp/510awtq
On deck:
MMP1000s
VTT aluminum outlets
SPOOL Helix 4x overdrive & filter
ISO:
2" Silicone relocation inlets
2" Silicone outlets - I'm not digging these VTTs
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 11-09-2013, 11:58 PM
Your car was definitely strong! TQ was just crazy. I am jealous of the IATs for sure. Good meeting all of yall !
335is DCT
Car: 2007 335i E92
Default 11-10-2013, 07:09 AM
Thanks Jgnp! I'm pretty happy with the results.
It was nice meeting you too MUSC.
|2007 E92 SGM 335i|
