Default 2020 C43 JB4 Dyno Testing - 11-06-2021, 05:40 PM
Was able to get a 2020 facelift C43 model in for a little test and tune fun!
Best run 100% stock on 91 octane was 340whp/350wtq.
JB4 (no BCM) on 91 octane testing was 380whp/412whp on map2. Really solid gains under the curve overall.
Next we decided to mix in 4 gallons of E85 for ~E30 and installed a BCM. Power jumped up to 400whp/488whp using (new) map5.
Finally we got to what we really wanted to test. The BMS intake using our new V3 heat shields (in development now), and got power up to 419whp/496wtq. I attached a log of that run for reference. Boost is up there at 21psi peak tapering to 15psi but nothing too crazy. Probably more in it next go around.
Finally for kicks we disabled the BCM so we could see what the likely max facelift power is without it. Peak was 413whp/447wtq but you could see the massive torque reduction down low in the charts. The BCM does wonders for facelift cars running E30!
We were not able to test 91 octane + BCM but I don't expect it would do a ton. Maybe on 93 octane... Next time!
spike98 spike98 is offline
Car: 2018 340i
Default 11-09-2021, 04:30 PM
Default JB4 settings?
Default 11-10-2021, 09:33 AM
Yes, off the shelf JB4.
Sleepys4 Sleepys4 is offline
Car: 2020 c43
Default 12-28-2021, 08:54 PM
Sorry to post in this.
Have you guys gotten a check engine light for low fuel pressure. Had one twice in 2 weeks on stage 3. Hit the limiter a couple night ago and it popped on as well. Have you guys seen this before? I was reading another thread where someone hooked up a green wire?.
The car is a 2020 C43 convertible, BMS intake, JB4, BCM.
MatthewJ MatthewJ is offline
Car: C400
Default 12-29-2021, 07:06 AM
Would you expect the same power curve changes with the BCM on non-facelift?
Default 12-29-2021, 09:04 AM
Not quite as pronounced but should still see a nice torque boost with it.
hotbrick hotbrick is offline
Car: M4
Default 12-31-2021, 06:28 PM
This will also work for 2022 GLC43 right? Should be the same numbers?
Default 01-01-2022, 10:56 AM
Yes!
Car: M4
Unhappy 01-01-2022, 06:23 PM
Ok ready to order. Literally drove this thing off the lot two nights ago. Lol
This is what I need right?
Default 01-02-2022, 10:01 AM
Correct
Car: M4
Default 01-02-2022, 05:14 PM
Ok thanks order just placed
