(#701)
Angel67's Avatar
Angel67 Angel67 is offline
Car: 335xi
Default 08-24-2021, 03:00 PM
What about Bit 1 - disable WG adaptation? Leave off or enable?
E92 335xi
Hokie135 Hokie135 is offline
Car: 2009 135i
Default 08-30-2021, 09:47 AM
Thanks Terry.
Here's my Map 2 log. The only thing to note is that now I am using the new T9 firmware. Let me know if you are seeing anything different based on your changes.
MODS
93 Octane, JB4 G5 w/ BEF, Pure Stage 2 Hi-Flows, 3.5 TMAP, 2" Inlets, 2" Outlets, DeePees, Walbro 535 LPFP, Bosch OEM Plugs, Eldor Coils, BMS DCI, BMS OCC.
Stevae's Avatar
Stevae Stevae is offline
Car: 2009 BMW 335i E92
Default 09-21-2021, 05:16 AM
Ill have to check it out. I thought all settings in map 5, 2, etc were defined in map 6 settings and carried over.
Did you ever confirm this? Could you post a screen shot of your full user settings in the JB4? I'd just like to compare them to what I have mine set to. Thanks.
2009 E92 335i: M-Performance exhaust, VRSF ***less DP's & upgraded inlets/outlets, Upgraded Turbos Hexon RR600s, VRSF 7.5" FMIC, aluminum Charge Pipe; Forged aluminum Diverter Valves w upgraded Yellow Springs, Walbro 450 LPFP, Spec Stage 3+ clutch w SMFW, Custom welded RB external PVC w ported & polished heads from Motiv, 3.5 Bar TMAP, BMS dual OCC's, BMS cowl delete & DCI's, Index 12 Fuel injectors, M3 suspension, KW v3 coilovers. JB4 G5 &/or MHD custom tune by Jake from Motiv Motorsports.
Car: 2008 E93
Default 09-21-2021, 03:40 PM
Went back to previous firmware.
I noticed oscillations that are not present in older firmware logs.
I would think I could tweak things and smooth them out a bit, but rather keep it simple.
Couple years ago I had updated firmware and my PI was a mess. Had to adjust some settings.
Same with beta now since PI got rescaled again.
That along with the oscillations made me revert and leave it alone.
Beta firmware still looks promising, I will try it again later on if any changes are made.
Angel67's Avatar
Car: 335xi
Default 09-21-2021, 03:52 PM
I am still on older firmware, as you know. But I have now enabled bit 6 and I have been playing with the DB settings for a couple of weeks. My boost is now almost perfectly at target. I have also noticed that before I enabled Bit 6 I would get some studder occasionally at low rpms, say around 2500 at low throttle. That seems to be gone since I enabled Bit 6.
E92 335xi
Car: 2008 E93
Default 10-02-2021, 10:52 AM
Is anyone running Beta 32/16 without issues now ?
Just want to compare some notes.
I am trying it again this weekend as I am one of the people who actually asked Terry if he could make 2 user adjustable maps long ago.
temperamental's Avatar
temperamental temperamental is offline
Default 10-04-2021, 01:25 PM
@the beast
The T9 version is good so far. Exhaust is still louder then hex 32_15 but i am getting used to it. On map 6 i had to put in my own boost targets and FB & DBs. Dialing in PI is next on my list...currently i am just driving the car to get used to the firmware changes.
JB4 Flex Fuel //MMP Stage 3 turbos//Custom Exhaust/BMS DCI//FMIC/KW suspension//Fuel-it Pi & Fuel it stage 4/BMS OCC's and too much to mention
Car: 2008 E93
Default 10-04-2021, 02:32 PM
Originally Posted by temperamental
@the beast
Have you compared logs before and after ?
The loud exhaust was due to wgdc going to ZERO when lifting throttle. Fixed in T9.
KClemente KClemente is offline
Default 10-04-2021, 10:57 PM
32/16 has been usable to me since T7, but there is still a bug with the spool up logic in where the WGDC will oscillate during highway cruise where 1-2 psi of boost is commonplace.
That 18-30% wgdc oscillation definitely isn't helping the poor wastegate arm
Car: 2008 E93
Default 10-05-2021, 10:00 PM
Have you noticed anything else besides that ?
What mods ?
Any PI ?
Default 10-06-2021, 12:12 AM
What mods ?
Any PI ?
17t's full ethanol, 70/30 methanol, dual pumps and a Helix.
I haven't noticed anything else lately. Just normal JB4 stuff like the occasional over-boost when it feels like it.
DCTiS DCTiS is offline
Car: 2011 bmw 335is DCT
Default 10-12-2021, 05:02 AM
Hey Terry & Steve
Heres a map 2 on inaos_pump BEF 94oct, fuel stage 2 450pump, vtt f-rb lites, fbo, inlets, outlets, catt*d ***, 7.5 BMS race intercooler. N54 335is DCT xhp stage 3
Car: 2008 E93
Default 10-12-2021, 08:54 PM
Originally Posted by DCTiS
Hey Terry & Steve
You need better fuel. Higher octane.
Default 10-13-2021, 06:00 AM
thanks the Beast i have purchased the bms methonal kit with dual cm10s just have to install it in the coming weeks. would you have any further settings recommendations for the jb4 ? run map 1 or run map 5 to keep things on the safer side? wasnt sure if was safe to run map 5
Car: 2008 E93
Default 10-13-2021, 08:39 AM
Once installed, post a log on low boost, and take it from there.
Default 12-28-2021, 04:55 PM
Hey Beast
Finally got around to installing the Meth kit. Im using the MHD Pump 2 bef and map 3 default settings. What are your recommendations for further improvement ?
Kind regards
Default 12-28-2021, 05:19 PM
Hey Beast
Kind regards
post this in the N54 support section
Default 12-28-2021, 06:08 PM
Hey Dave
Sorry i thought this was support for the hybrid turbos
Currently have listed mods :
Default 12-28-2021, 08:50 PM
Hey Dave
Starting your own support thread is much more affective and less confusing.
