(#676)
temperamental's Avatar
temperamental temperamental is offline
Default 07-11-2021, 12:25 PM
FB, DB and user settings that were out of whack.
JB4 Flex Fuel //MMP Stage 3 turbos//Custom Exhaust/BMS DCI//FMIC/KW suspension//Fuel-it Pi & Fuel it stage 4/BMS OCC's and too much to mention
Car: 2008 E93
Default 07-11-2021, 12:30 PM
Ill have to check it out. I thought all settings in map 5, 2, etc were defined in map 6 settings and carried over.
Default 07-11-2021, 12:35 PM
My map 5 and map 7 fuel and duty bias settings looked like the attached screenshot.
Car: 2008 E93
Default 07-11-2021, 01:57 PM
Ill have to check it out ....never looked into map 5 settings, EVER.
Even when I would ocassionaly use map 7, always used steering wheel controls, select map, and let her rip...
KClemente KClemente is offline
Default 07-11-2021, 08:34 PM
Flashed T6 yesterday and saved settings in Map 5,6,7,8 and it hasn't reset on me yet.
Car: 2008 E93
Default 07-11-2021, 09:15 PM
Nice......seems we have a winner !
Issue seems to be resolved!!
DCTiS DCTiS is offline
Car: 2011 bmw 335is DCT
Default 07-31-2021, 01:33 PM
i have a 2011 bmw 335is DCT list of mods being Cobb exhaust, stage 2 Fuel it 450walbro, VRSF catted *********, VTT Stage 1 with billet wheels, MMP outlets, BMS inlets, ECS enclosed intake, CSF intercooler, BMS chargepipe, Turbosmart kompact DV kit, Mishimoto OCC, delphi 153s coils ngk 97968 gapped to .022 mhd jb4 inaos pump flash loaded. Bit 6 turned on and menu 4/2 was hoping to get some assistance as what i have done incorrect not to hit target at all? I replaced my low pressure fuel sensor and high and at the end of the log i picked a mis fire on cylinder 1
Default 08-02-2021, 09:28 AM
Settings look okay but your WGDC is really high for that boost level. Not sure what the issue is...maybe a boost leak? Low pressure and high pressure fuel looks fine.
Default 08-02-2021, 03:13 PM
Hey steve
Figured it out. Brand new sensor was faulty had fuel coming up through the pins of the connector. The next day after sitting i could smell the fuel. Thinking the sensor was loose i removed it and re installed it. Fuel started pooling in the pins itself. New sensor ordered. Will report back maybe 3rd time is the charm as for logs haha.
Default 08-05-2021, 09:17 AM
Wondering if i could get some assistance as too why the car is not making boost. Iv attached a log. Iv replaced all the plastic lines from the dealer no codes no lights.
i have a 2011 bmw 335is dct 94oct. stage 2 fuel it fuel pump. COBB exhaust VRSF catted ***. Vargas VTT stage 1 turbos with billet wheel. MMP silicone outlets, CSF intercoolerARM silicone 3 inch j pipe, BMS charge pipe, Turbosmart Kompact DVs, ECS carbon fiber enclosed intake. BMS silicone inlets, rb pcv, mishimoto catch can. NGK 97968 0.22 gap, delphi 153 coils
ram00sa ram00sa is offline
Default 08-10-2021, 10:54 AM
I didn't find any hybrid pump map or hybrid pump meth map
KjKeyz KjKeyz is offline
Car: 335XI 08'
Default 08-14-2021, 04:48 AM
See the first post on the first page.
"4) Use the flash map that most appropriately matches the octane to be used. For pump gas no meth use PUMP, for pump gas with meth or light E85 or race gas mixtures use RACE, and for 40% E85 or more use E85 HYBRID map.
2008 335xi | JB4 | VRSF Charge pipe | VRSF 7in. HD intercooler | VSRF Aluminum Outlets | VRSF Down P!pes | RB silicone inlets | BMS Dual cone intake | Turbosmart Kompact Dual Port BOV | RB PVC valve | OCC | RB 2+ Turbos
Car: 335XI 08'
Default 08-14-2021, 04:50 AM
How do you save settings on each map individually? Do you set the JB4 via steering wheel controls into the map you want and then go to the settings in the app and they will correspond with the map that's currently selected?
Angel67's Avatar
Angel67 Angel67 is offline
Car: 335xi
Default 08-14-2021, 02:32 PM
Hey guys, I just noticed my Bit 6 (hybrid turbos installed) is set to off. I have MMP turbos. The car was dyno tuned and I have not touched the settings since then. Should bit 6 be on?
E92 335xi
Default 08-15-2021, 12:19 AM
The answer is yes....bit 6 must be on/activated.... So that the Jb4 can recognise you running a backend flash.
But as The Beast has mentioned to you in annother thread, it depends on how your tuner has set up your tuning and what flash you running. The latest firmware 32/16 changes the Jb4 mapping when bit 6 is enabled. Why not post up a log to assist Terry or Steve to advise you on your current settings.
Angel67's Avatar
Car: 335xi
Default 08-15-2021, 03:41 AM
But doesn't jb4 recognize the BEF because menu 4 is set to 2?
Attached is a log from a quick gear 2 and 3 pull yesterday. Gear 2 is a bit wonky but 3 looks ok. I wasn't testing. I was just passing somebody...
E92 335xi
Default 08-15-2021, 04:47 AM
Activating Bit 6 takes advantage of the latest firmware 32/16 and since you on very old firmware 32/9 i doubt it will benefit you.
Talk to your custom tuner but consider updating your firmware and to the hybrid settings.
You can read up on the changes in this thread page 24 post #581 where Terry introduces the latest changes.
Angel67's Avatar
Car: 335xi
Default 08-15-2021, 06:03 AM
Many thanks and will do some more reading and talk to my tuner and report back.
E92 335xi
Hokie135 Hokie135 is offline
Car: 2009 135i
Default Pure Stage 2 Rebuild Log Review - 08-17-2021, 09:27 AM
Been lurking for over 10 years but I've finally decided to rebuild the 09' 6MT 135i.
I'm running: JB4 G5 w/ BEF, Pure Stage 2 Hi-Flows, 3.5 TMAP, 2" Inlets, 2" Outlets, DeePees, Walbro 535 LPFP, Bosch OEM Plugs, Eldor Coils, BMS DCI, BMS OCC.
Please take a look at my last run (Map 1 w/ Page 1 Settings) and let me know if you are spotting anything. Comparing a jillion other logs makes me feel like it's ok but I'm iffy on the timing numbers and things like that still.
Also big shout-out to Terry. I upgraded to the G5 board finally but had an old harness. Had the Wastegate Activation fault that was driving me bonkers (even after changing the wiring) and he gave me a discount on a new harness. Now it's running strong. He didn't have to do that and did it anyway. He's a good one.
Default 08-18-2021, 07:26 AM
Nothing jumps out on log as problematic, run map2 next.
Angel67's Avatar
Car: 335xi
Default 08-22-2021, 10:58 AM
Interesting. I've compared a bunch of logs over the last year. Two observations when comparing the last two (with Bit 6 enabled) and all the previous ones (with Bit 6 disabled):
1. For all the previous ones (Bit 6 disabled) boost is on target except for an initial spike at spool, and WGDC very closely follows FF (which is good).
2. For the two new ones (with Bit 6 enabled), there is no initial spike but it is underboosting after 4,000 rpm, and WGDC is no longer following (is trending up compared to) FF.
3. Before enabling Bit 6, my FF/Wastegate adaptation was at 33, and since I enabled Bit 6 it has moved up to 50.
I read Terry's post on page 24 about v16 and how the targets have been bumped. Definitely interested so would like to try. But has the issue been resolved with respect to settings not being saved?
E92 335xi
Angel67's Avatar
Car: 335xi
Default 08-22-2021, 01:28 PM
So I reset everything (Bit 6 disabled and reset FF / Wastegate adaptation to 33) and this is what I got on a 3rd gear pull a few minutes ago. No spike, and boost is back on target. FF / Wastegate adaptation did however adjustitself to 45. And WGDC and FF are not perfectly aligned although now back to trending in the same direction, so overall better than with Bit 6 enabled. Undoubtedly can do better with Bit 6 enabled and some DB tweaking, but will wait till next week when the weather is a bit cooler and less humid, and may even try v16...
E92 335xi
Angel67's Avatar
Car: 335xi
Default 08-22-2021, 01:44 PM
Does this mean that with certain DB settings it may be better to disable Bit 6?
Should also mention this was a Map 5 run, on Canadian 94 pump gas (which is basically 91 with an e10 mixture), at about 30 degrees Celsius (86f), with IAT at about 36 (97f) and very humid, at an altitude of about 1,100 ft above sea level.
E92 335xi
Car: 2008 E93
Default 08-24-2021, 01:34 PM
On hybrids , you do want to disable rpm ff gain, raise ff manually or let it adapt.
Once it adapts, boost will be more on target, after that, you can tweak db as needed.
Let it adapt. Do not go changing a bunch of stuff at once.
Angel67's Avatar
Car: 335xi
Default 08-24-2021, 02:47 PM
Ok, good thoughts. Many thanks, BEAST.
Stay tuned.
E92 335xi
