Corleone1 Corleone1 is offline
Car: Stinger 3.3
Default Stay in manual gear? - 05-16-2021, 01:24 AM
Hello
Is there any "hack" that its possible to choose if I want to stay in manual or auto for the 3,3 Stinger?
Car: Stinger 3.3
Default 05-20-2021, 05:05 AM
No one thinking of this more than me?
Default 05-22-2021, 08:44 AM
Nothing I'm aware of other than shifting to manual mode.
Car: Stinger 3.3
Default 05-22-2021, 09:06 AM
Would be good to choose myself when going back to auto. Just about when I need manual it went back to auto...
turboAWD turboAWD is offline
Car: Stinger GT
Default 05-23-2021, 03:38 PM
Are you asking to increase the delay after shifting with the paddles in "auto" mode, before it goes back to auto?
Or are you asking for way to stay 100% in manual mode, once you activate it?
Car: Stinger 3.3
Default 05-23-2021, 09:17 PM
First one would be ok but good to decide on and off. So how can the auto delay be longer...?
Car: Stinger GT
Default 05-23-2021, 09:21 PM
Sorry, I should have included in my original post: I have no idea how to do the first one - I don't think it exists as a user-adjustable setting.
In case you were asking about the second one, that is possible on GT/GT1 and maybe GT2. I have GT1, so I know it can be done. I'm not 100% sure about GT2.
D-Rail_Trail D-Rail_Trail is offline
Here 4 knowledge
Car: 2021 Kia Stinger GT2 AWD
Default 05-24-2021, 04:14 AM
Originally Posted by Corleone1
Hello
I assume you have a GT2 (shift-by-wire) as do I. I have read multiple threads on multiple forums, as well as owners manual trying to find a way mainly for logging purposes such as a full 4th gear pull. I have found nothing. Shift to the gear you want and go WOT and the car automatically downshifts a gear or 2. It sucks. I anticipate it and just stay WOT and shift back to preferred gear right away to get the pull for the log.
Car: Stinger GT
Default 05-24-2021, 06:27 AM
Have you tried doing the 2-stage traction control / stability control disable?
That's how to do it on my GT1 - do the 2-step disable (as needed for launch control) and be in manual mode by moving the shifter over to the left.
Here 4 knowledge
Default 05-24-2021, 12:39 PM
There is no lateral movement in this shifter. Reverse, neutral, and drive is it.
Car: Stinger GT
Default 05-24-2021, 02:27 PM
Yes, I know. It's one reason I got the GT1 instead..
What I don't know 100% is if you do the 2-stage disable, if you still get the "shifts back to auto after a while" behavior.
Here 4 knowledge
Default 05-25-2021, 04:07 AM
I'm not sure about that. I've only stayed in manual long enough to run my logs for the most part. I have a 700 mile drive home Friday I'll test it out.
