Viorage Viorage is offline
Car: 2007 BMW 335i
Default 11-30-2014, 09:49 AM
Originally Posted by deltalima0
E85 makes big power just so you know all your in for with E85 and running an aggressive to moderate tune. Your gas milage will be ass, some people claim to get 18-20 mpg on E85 I average like 14-15 mpg.
I dont care about fuel mileage, its not a Daily driver. My car has under 30k on it.
In my situation would you still spend the extra bucks to get the CP with Meth/bungs just in case? The price difference is hardly anything.
Car: 2007 BMW 335i
Default 11-30-2014, 09:55 AM
My friend just told me to run E85 I will have to upgrade my fuel system. What will I need to for this upgrade.
Car: 2007 BMW 335i
Default 11-30-2014, 10:11 AM
Looks like stage 2 or 3 lpfp + hpfp or PI upgrade for E85. PI is Pump injectors, correct?
Car: 2007 BMW 335i
Default 11-30-2014, 10:54 AM
need to do some digging to find the hpfp and injectors. Walboro is what I was recommended
GetSomeE92 GetSomeE92 is offline
Car: '09 E92
Default 11-30-2014, 08:09 PM
You probably won't need to upgrade anything in your fuel system unless you want to run a high percentage Ethanol blend (E40-60). The only way to know for sure will be to take some data logs of your low pressure fuel pump (LPFP) and high pressure fuel pump (HPFP) performance. You'd only need port injection if you wanted to run on 100% E85 (no blend). You'll be fine installing a LPFP upgrade to run up to around an E60 blend or otherwise max out the HPFP.
335i Coupe: E85 BB flash, JB4 G5 ISO (map 7), DCI and 60% E85 blend: 11.7 @ 120 mph.
Former Best with JB4 (G4, map 5) DCI and 40% E85 blend: 2009 BMW 335i Coupe: 12.173 @ 109.490 MPH
