H8D 535 H8D 535 is offline
Car: 2009 535i
Default change low fuel pressure sensor.. - 05-24-2013, 06:47 PM
What's going on fellas name is Jose from Cali with 09 535i love the car! Mods only dci and jb4. I got a code about my sensor so I just got the part..curious is their a DIY? Ill be honest not to familiar with BMW's...I did do the dci and jb4 which wasn't hard...how hard is this? Better to have a shop do it? Also when I look things up with this issue I see something about recall on our cars with this or HFPF or something like that..what's the recall for? Thanks for the helps guys please be easy as I am a newb!
Car: 2009 535i
Default 05-26-2013, 09:12 PM
45 views and nothing? Has ne one replaced these?? I don't bite lol any help would be greatly appreciated
e91 335i e91 335i is offline
Car: BMW e91 335i
Default 05-26-2013, 09:51 PM
I found these threads useful:
http://www.e90post.com/forums/showth...=286527&page=3
http://forums.5series.net/diy-do-you...or-n54-124086/
I did not remove the intake. It is very helpful to make the tool to remove the black box. Just get a peace of hard metal and bend it with heat. You can also try to bend a screwdriver to make the tool. Here are the steps i made:
- Disconnect the battery (just in case)
- Remove DCI's, the cowl etc.
- Remove the engine cover
- Remove the charge pipe
- Remove the throttle body
- Remove the black box using the selfmade tool
--> Now you can see the sensor
- Remove the sensor using 24mm wrench (not tight)
- Change the sensor
- Put everything back
Hope you found this useful!
Car: 2009 535i
Default 05-28-2013, 11:37 PM
Much appreciated I will try this tomorrow!
Car: 2009 535i
Default 05-29-2013, 05:52 PM
Hey guys just did this everything went smooth but my gas gauge still reads empty as it did that once I started to get the code of a my fuel sensor. Suggestions?
Car: 2009 535i
Default 05-29-2013, 05:54 PM
Nvm lol thanks for the help and the links change out went very smooth that tool helps!
