dwithane60 dwithane60 is offline
Car: 2008 535i E60
Default 05-20-2022, 08:14 PM
I have a 3100, 2A82, and 2A87 code. Its resulted in low power and a rough-idle on start up but it goes away after 4 seconds after readjusting itself. Did you also have these symptoms?
TheMidnightNarwhal TheMidnightNarwhal is offline
Car: 2011 335is 6 speed
Default 05-22-2022, 05:45 PM
I do not.
Default 05-25-2022, 06:11 PM
I'd like to add that, perhaps in your case both your camshaft bearing ledges are to be replaced. I noticed from my searching, that when it was the exhaust bearing ledge that was to be replaced or people were having exhaust codes, people were having bad idles and rough running. If you did all the other troubleshooting already (Oil filter cage, VANOS solenoid, VANOS filter check valves) I'd check the camshaft ledges.
Default 05-26-2022, 01:45 PM
Originally Posted by gordon513
Yeah I did DIY it - I'm fairly confident in terms of home mechanics and have worked on cars for years but regardless of skill this is quite an easy job, especially if you follow a guide. IMO, you don't need to worry about that alignment tool/ valve tool - the trays have dowels to keep them aligned and once you get them tightened down, you can feel with a finger nail if they are misaligned. Just tighten them down evenly and make sure none of the rollers fall off the top of the cams. Only certain valves are up at top dead centre so you just ne
Cheers
Hey gordon513, I had a bit of questions regarding the tray alignement.
I just put back in my exhaust cam now and unfortunately I can definitely feel the alignement isn't 100% with my fingernail. It catches going up on one side and catches going down on the other. Was yours really perfect? I'm this close to just say **** it and run it like this, the worse I can think of happening is needing a new ledge.
TIA!
Default 06-08-2022, 05:01 PM
Update. I finished the job. Ended up borrowing the C clamp special tools from someone and the alignement felt perfectu sing that.
gordon513 gordon513 is offline
Car: e82 135i N54 & E92 M3
Default 06-10-2022, 09:50 PM
TIA!
Sorry to have missed this but glad you got the job done in the end. When I first tightened mine down I could feel it was slightly misaligned so I loosened off the bolts on the cylinders that were under tension and then tightened them back down in an 'equal' sequence - seemed to work for me. By the clamps were probably a better option!
Current:
E82 135i 2010 (N54 Manual)
E92 M3 2010 (DCT)
Past:
F22 M235i 2015 (Auto)
E87 118D 2007 (Manual)
Default 07-26-2022, 08:14 PM
Just figured I'd do another post here to confirm my issue is definitely resolved as well. Got my liscesne back and took it for a drive and did not get the code in the same way I drove before. Have a little bit of metal shaving in the filter though but I think it's just normal wear in, I will check again in ~ 500KM.
Image link
