Car: 2007 335i
335is DCT? -
08-19-2016, 10:52 PM
I'm thinking about selling my 6MT and buying a 335is with a DCT. I'm going to mod it, and want to know what are the pros/cons about this platform.
08-20-2016, 04:00 AM
pros - faster shifting, no shift bog, better looks
cons - car is more expensive, upgraded clutch packs are expensive
One tire fire
Car: E92 335, 6MT
08-20-2016, 07:39 AM
I've had 3 335s in the past and the 335is with the DCT that I have now is by far my favorite. The transmission is excellent and really, really complements the N54 as you mod it. It has a much different feel to it than the regular auto.
'18 Magnetic Gray Raptor
'19 GT3 RS Weissach
'09 997.1 6MT: FBO, 65mm VTGs. 730 whp
'18 Nardo Gray RS3 APR stage 2, 10.72 @ 130
335is 7DCT/JB4
Car: BMW 335IS 7DCT/JB4
08-20-2016, 11:30 AM
There are no cons!!!
Kevin
2018 440 MPPSK/MPE
2014 435 MPPK/THP
2013 135is 6MT/JB4/ISO
2011 335is 7DCT/JB4/ISO/BMS Flash(sold)
FF Cobra Mk-IV COYOTE BOSS + TKO-600
Car: z4
08-21-2016, 03:45 PM
the only con I can think of is trying to launch it (if you are fbo)
Car: BMW 335is
08-21-2016, 04:50 PM
I've actually just done a similar change (E90 335i xDrive with a manual to 335is with DCT) and I love the near instant manual shifts along with the smooth automatic shifts when moving around town. Yes, there was quite a price difference but with what I wanted to do with the car, it made sense to make the change.
Car: 2007 335i
08-21-2016, 08:34 PM
I took one for a test drive last week, and loved everything about it. What do you plan on doing with yours?
Car: BMW 335is
08-21-2016, 09:02 PM
Everything I planned on doing with my E90. I purchased Pure's Stage 2 turbos a while ago and they were delivered over a month ago and they've been sitting in my kitchen along with various supporting add-ons like inlets, outlets and port injection. I have an MFactory LSD coming in this coming week as well.
If the clutches start slipping or the transmission seems to start overheating at the track, I plan on throwing in SSP Performance's clutches or their heavy duty cooling package respectively.
Plenty of go fast bits while retaining most of the low-end torque.
The main reason I switched away from my previous car is because of the added weight and drivetrain loss due to xDrive wasn't something I was a fan of and I figured if I was going to make a BMW go fast, I might as well do it with the drivetrain it was made for and enjoy a little bit of sliding at the track. The DCT was just a nice touch to sweeten the idea. If I had hated the DCT, I probably would have gone with a manual 335is.
Car: 335is
08-21-2016, 10:00 PM
That's what I did, couldn't be happier. Hate automatics.
Car: BMW 335is
08-22-2016, 05:46 AM
My first four cars were manual (and this 335is is now my fifth) so I felt the same way. For others, I recommend at least giving the DCT a try and seeing how you feel about both before making a decision.
Car: 2007 335i
08-22-2016, 01:06 PM
Are there any DCT flashes?
Car: BMW E92 M3
08-22-2016, 01:12 PM
DCT's are the way forward, and has been the case with every car that I have owned
Every car that I own now is a DCT, and do not even miss an MT one bit (especially in traffic! lol)
Car: 335is
08-22-2016, 04:40 PM
In that sense, self-driving cars is the way forward. You won't miss driving one bit.
08-22-2016, 04:51 PM
We have a 2012 335is DCT. Nice car and it shifts fast. As long as you keep it under 550whp shouldn't be an issue. Above that and you may need to upgrade the DCT clutch packs.
Car: BMW 335is
08-22-2016, 07:09 PM
There isn't a performance flash or anything (like Alpina flashes for the standard automatics) but there is a flash to lower the launch control RPM from 5000 to 3500. You can find it talked about here and steps at the bottom of the page if you're familiar with WinKFP. I've successfully done the flash and confirmed that it revs to 3500 RPM but I haven't actually launched it with the change yet. I'm waiting for my LSD to get in and to install a differential brace to reduce the wheel hop.
Car: 2007 335i
08-22-2016, 07:36 PM
I know there's always an issues with traction with n54's. But with DR I was able to grab traction with every launch. Have you tried Drag radials?
Car: 2007 335i E91
08-22-2016, 08:19 PM
It seems the Euro makers are steering away though going 8 speed triptronics. Freind just got a 340i
Car: 2007 335i
08-22-2016, 09:25 PM
I noticed that too. Times are changing for the automotive industries, 8 speed, 9 speeds, and eventually 11 speed transmissions soon, in the name of efficiency; even thought manuals will always be more efficient then any auto.
Car: 2007 335i
08-22-2016, 09:30 PM
What do you offer for the DCT guys?
Car: N55 135i
08-23-2016, 03:40 AM
Here you go - jump to post #57
http://www.n54tech.com/forums/showth...t=40495&page=3
Car: BMW 335is
08-23-2016, 07:37 AM
I just got the car on the 15th so I definitely haven't had the chance to do that..
I don't plan on taking my car to the drag strip often though. Once everything is bolted on, I'd like to see what I can do for a quarter mile time but I'm more interested in setting the car up for road courses or highway touring.
Car: BMW 335is
08-23-2016, 07:39 AM
Originally Posted by keyap
Interesting. Should be a nice read. Thanks for the share!
Car: BMW E92 M3
08-23-2016, 07:58 AM
Car manufacturers will always make AT/Tiptronic (be it 6/7/8spd etc, as high-end luxury cars will always use this e.g MB, Bentley etc), especially with advances in the TCU programming, and they are going this route with more gears for the DCT as well (my DCT is 7spd)
DCT isn't a replacement for AT; it is an upgrade on the MT, and will replace MT on high-end sports cars (if they already haven't done so. Most already have). Same control as offered by MT, quicker shift times, less clutch wear, idiot-proof (it's impossible to do a 1-2-1), more convenient and, most importantly, safer.
You need to remember, a DCT is NOT an AT (although it does offer an AT function, normally the default setting until you change the shift mode. The AT function is software-related, not hardware-related. An AT is hardware first and foremost).
MT has it's place for die-hards, but drive (and appreciate) a DCT for long enough on both street and track, and you will start wondering why you even bothered with a 3rd pedal.
An analogy for those OAP's like me: Back in the 90's when I had a mobile phone, everyone thought it was pointless and that I was just a poser. Fast forward to the 21st century and guess what? Most people would be paralysed without a mobile phone, and most of the 21st century generation won't even remember a time without one. How many people even use a landline at home anymore?
Car: N55 135i
08-23-2016, 12:45 PM
If you go DCT and are looking for high power then slip may be a factor.
I'm not familiar enough with the n54 platform to quote specifics but with the N55s, anything over 18 to 19psi and you'll start to slip.
With the N55, this can be resolved via two options - a DCT flash which can give you a few more PSI or a high load BEF (flash which lets the DME see increased boost and triggers the DCT to apply more pressure).
I'm guessing with the more advanced N54 tuning options there may be other ways too.
Car: BMW E92 M3
08-23-2016, 12:49 PM
Upgraded clutch packs
Expensive (for now), but they do exist.
Thread Tools |
Display Modes |
