With the JB4 you can run its internal virtual flex fuel sensor, or add on a Fuel-IT physical sensor, and the JB4 will use either to rescale port injection as needed for the specific mixture.
With a Stage2 low pressure pump probably starting with a 50% mix is good and then evaluate from there.
Will JB4 modify timing, fuel, boost, etc to run higher HP based on the fuel-it physical sensor? I just want to run whatever fuel and let the car tune based on the E85 content. I don't want to have to mix 50/50, and do all sorts of different tunes.
