Sw4y1313 Sw4y1313 is offline
Default VTT GCs 3rd gear boost issues - 06-25-2017, 10:57 AM
Good morning,
I don't usually ask for help with logs on this thing, but after flashing the newest firmware, 3rd gear boost target is almost completely ignored. Last night while I was doing some brake-boost runs, 3rd gear boost target looks to be almost completely ignored. Even if I rolled into 3rd gear it does the same thing. 4th gear no issues.
JB4 is on latest 32_8 firmware. That is honestly the only thing changed since I've had this running with Port Meth Injection (aside from my old FSB failing and injecting meth at idle).
Any ideas?
2008 E92 AW 335xi 6MT: VTT GC Turbos w/ Inlets n Outlet + JB4 + Custom BEF + BMS CP + BMS Meth kit & TwistedTuning DP Meth Plate + 6 Aquamist .4mm Nozzles & 350cc 7th nozzle.
Default 06-26-2017, 12:12 AM
I don't see it being ignored.
Pulling some timing.
Overboosting a little up top, but you can lower DB's. In addition, I'd put PID gain back to 25.
Default 06-26-2017, 09:00 AM
In 3Rd my boost just continues to climb past my target. That's why I say it looks like it's ignoring it. I had my db settings perfect up until I flashed new firmware. Now this starts to happen. I know timing is crap because It can handle 21psi on my current fuel, not 25+ like it was seeing.
Why would duty bias be all jacked up after firmware upgrade? I had that dialed in perfect before. And in 4th gear it holds boost fine too.
N54QC N54QC is offline
Car: 07 BMW 335i
Default 06-26-2017, 02:33 PM
Weird part is I was experiencing the same thing after the update. I can't view your log from my work computer to see what it's doing but mine seemed to be off on the third gear pull and back on in 4th even though DB's were dialed in. Haven't pulled logs lately, it's just strange that you mentioned this as I was experiencing a similar thing after my update.
Default 06-26-2017, 05:30 PM
May have been some changes in the new firmware that affect it, dial DB's in and you should be good.
Default 06-26-2017, 05:34 PM
If boost is going over target then adjust dutybias in that range as needed. Simple stuff.
Any time you are tuning larger turbos you should disable the built in RPM FF gain so you can manually dial in duty bias. Note the default settings: http://www.n54tech.com/forums/showthread.php?t=33200
nuttifriendivan nuttifriendivan is offline
Car: BMW 335i MT
Default 06-26-2017, 09:30 PM
I feel like we're ignoring the fact that even though 3rd gear is way off.. 4th gear is hitting target just fine.
2008 335i 6Spd Manual MMP Inlets- Clutch Delay Valve delete- BMS ********* - SLD- G5 Jb4/ USB. FMIC ******* DP's- M3 wheels- 2/step NLS- MHD custome e60 flash JB4 stacked - Walbro Inline Upgrade stage 1- 335is Clutch - DMFW - Pilot Super Sports -ECS tunning Chargepipe - w. Synapse BOV- Gutted 2ndary Cats - Throttle Body Port injection by Fuel -IT! Kidner grill,scoops.
Default 06-26-2017, 09:42 PM
I did this when i first installed the turbos, its how i dialed in the duty bias in the first place. I also just did this on Todd H's(prelude) car this past weekend on his new RB Next Gens and his car did the exact same thing after dialing in duty bias and then unlocking FF again. His boost in upper rpms skyrocketed like crazy.
And as said above, 4th gear has no problems. I can post more 4th gear single gear logs and its dead on target. Go to 3rd gear, completely off.
Car: 07 BMW 335i
Default 06-27-2017, 12:29 AM
Are you saying that you enabled FF gain after you dialed in DB's? If so, you are suppose to keep the bit disabled, even after dialing in DB's.
prelude2perfect's Avatar
Car: '07 335i
Default 06-27-2017, 01:49 PM
You sure? I don't recall Terry putting that information out
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
Car: '07 335i
Default 06-27-2017, 01:56 PM
I was in the car and reading the logs when this happened. Seemed like it was solely related to brake boosting. I highly doubt it's duty bias related as it was perfect before these brake boost runs.
Best 1/4 ET: 11.4
Car: 07 BMW 335i
Default 06-27-2017, 05:46 PM
Yes, I have asked the question before because I was unsure at the time after installing my hybrids. Leave FF disabled even after dialing in DB's.
Car: '07 335i
Default 06-28-2017, 08:09 PM
That contradicts what Terry says on post # 86 here: http://www.n54tech.com/forums/showth...t=29893&page=4
Best 1/4 ET: 11.4
neverwerks neverwerks is offline
Car: E90 335I
Default 06-29-2017, 12:58 PM
I'd like to confirmation on this as well
Default 06-29-2017, 01:12 PM
After finishing up duty bias wastegate adaption should be enabled again, unless there is some good reason you don't want to enable it.
Car: 07 BMW 335i
Default 06-29-2017, 01:32 PM
Well I apologize to those I may have told wrong, but are we talking FF rpm gain or wastegate adaptation?
Default 06-29-2017, 02:44 PM
So I have been doing duty bias tuning properly. And in my logs, it shows regardless of if I'm brake boosting or just rolling into the throttle, in 3rd gear, the JB4 is not holding target boost in the upper rpms. When target is 21psi, its hitting my boost failsafe of 27psi. But in 4th gear, it holds it perfectly.
My setup didn't change at all. I'm just not using meth currently because I can't get the new FSB to work.
Car: '07 335i
Default 06-29-2017, 09:47 PM
So it's happening without brake boosting now too huh? Very strange. I guess just adjust duty bias and see if it helps. Just strange because it was running great before that. When I drove it that one day it felt perfect
Best 1/4 ET: 11.4
Default 06-29-2017, 10:49 PM
That's what is frustrating me so much about this. I will mess with it this weekend.
Default 07-01-2017, 02:02 AM
I reflashed back to previous firmware, made no changes to duty bias and here is the result. This was the first 3rd gear pull in map7 after changing firmware. Aside from having to massage duty bias again, she holds target, unlike on the newest firmware.
Car: '07 335i
Default 07-01-2017, 12:41 PM
Very strange because I don't think Terry made any changes to this stuff on the recent firmware updates. I'd tag him, but don't remember how
Best 1/4 ET: 11.4
