(#626)
Default 03-10-2017, 09:15 AM
I thought we disabled the brake trigger if vehicle speed was less than 30mph.
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 03-10-2017, 09:43 AM
I thought we disabled the brake if vehicle speed was less than 30mph.
Why was the brake added in again? Seems way easier to just hold volume down and throttle 100%.
09 335 - 6266
07 335i - 6870, E85 - SOLD
Default 03-10-2017, 10:44 AM
Some people prefer to brake boost from a roll using the actual brake pedal.
JazRedGT JazRedGT is offline
Car: 2007 335i E-92 6AT
Default 03-10-2017, 12:26 PM
Terry yes I meant from a roll. At stand still you still have to use the volume
2007 AW 335i E-92 6AT MMP Stage 3 @ 25psi / JB4 G5 ISO / XHP STG3 / VRSF D-Ps / MMP INLETS&OUTLETS / WEDGE MHD E50 BACKEND / CW EXHAUST / CPe CP / GReddy RS BOV / BMS METH KIT / WAGNER IC / PR STAGE3 LPFP 10.92 @ 132 1.72 60ft 6.96 @ 103 1.55 60ft
Car: 2008 E93
Default 03-19-2017, 09:53 AM
Skimmed through this thread a bit. So the actual trigger is volume button down ? Any chance of accidentally triggering anti lag when not wanting to use it ?
No
Boosted614 Boosted614 is offline
Car: 335i Single Turbo
Default 04-22-2017, 11:32 AM
if I have the BB ST backend flash and latest JB4 G5 firmware, will I need to switch to MHD backend flash to make the anti lag work correctly?
I currently have a ST with pump gas and meth, so I'm not looking to go to a E85 map.
Just curious as what flashes can run it without e85.
Thanks guys!
Default 04-22-2017, 01:06 PM
No, works with BB or MHD BEF....
500hp500tq 500hp500tq is offline
Default 05-09-2017, 06:36 AM
Hey Guys,
For ST cars does the Volume down button work to engage antilag or only the brake petal?
|2008 135i N54 | VRSF FBO| Motiv Port Injection | BMS PI Controller| AD-E ST Kit 6062 | JB4 G5 ISO 13.0 | BMS ST/MHD E85 Flash | 60% e70 | Fuel-It Stage3 LPFP | Spec2+/SMFW |3.5 TMAP | NLS
"stock"
echofoxx echofoxx is offline
BMW Single Turbo N54
Car: 335i 07
Default 05-09-2017, 11:35 AM
On the 3/15/17 Map Release Backend flash My Anti-lag stopped working. I had to revert back to 2/23/16 Map Release. I used the ST pump fuel Map and now my Anti-lag works with Volume down button like before.
Originally Posted by 500hp500tq
Hey Guys,
Default 05-09-2017, 11:46 AM
What is the full file name you are having a problem with?
Car: 335i 07
Default 05-09-2017, 02:55 PM
The file i used was JB4_BB2_I8A0S_ST.bin from the JB4_BEF_031517.zip. Everything else seem to work fine but Anti-lag. I ended up reverting back to
JB4_BB_022316.zip - JB4_I8A0S_ST.bin
Default 05-09-2017, 04:25 PM
The file looks OK to me. Record a JB4 log on the 3/15 triggering anti-lag and lets check it out.
Default 05-09-2017, 04:29 PM
Esh, same BEF I'm using now. I'll test also tonight
"stock"
prelude2perfect's Avatar
Car: '07 335i
Default 06-26-2017, 12:06 AM
Out of nowhere mine starting triggering when brake boosting. Going to uninstall, I prefer brake boosting anyway. If anyone wants to buy it from me shoot me a pm
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
Default 06-26-2017, 11:03 AM
There is a setting to disable anti-lag while brake boosting if you need... Although you are better off keeping it active while brake boosting.
Car: '07 335i
Default 06-27-2017, 03:25 PM
Which setting? And how so?
Best 1/4 ET: 11.4
cmiggz's Avatar
cmiggz cmiggz is offline
Car: 2008 BMW 335i
Default 07-03-2017, 12:20 AM
Anyway to use this from a dig? Im ST and cant figure out how to build boost off the line. Thanks in advamce
Car: 335i 07
Default 07-03-2017, 06:16 AM
I set my 2-step to 4k and launch. It boogs a little with limited wheelspin and seems fast enough.
Default 07-03-2017, 10:01 AM
I know of a few people that use the anti-lag and a two-step at the same time.
cmiggz's Avatar
Car: 2008 BMW 335i
Default 07-03-2017, 11:17 AM
Im auto tho so idk how it would help.
Default 07-03-2017, 12:38 PM
Yes this customer is also AT. Says he has goodluck with them both
Twilly Twilly is offline
Car: 07 335i 6MT
Default 07-13-2017, 04:16 PM
Just installed my kit. Just wanna see if it works. I have latest firmware useing JB4 rev 3 kit. do I need a backend flash? What are the actions to activate the anti lag? Is there a minimal speed? Throttle 100%? I'm just trying to see if I installed it right. I know I'll need E85 to do it more frequently. Thanks guys!
Car: 07 335i 6MT
Default 07-13-2017, 04:25 PM
Also I only installed the wire. I have the chip but didn't install because I just bought my JB4 through you guys about 3/4 months ago and I read it should already have it. Is this correct?
Default 07-13-2017, 04:26 PM
Correct, no need to swap chip on newer JB4s.
