sanjaycollins sanjaycollins is offline
Car: 2021 Kia Forte GT Manual
Default Mazda3 2.5T Data Logs - 01-04-2022, 10:19 AM
Hey, would you guys mind looking over these data logs, please? I attached one map 1 log and one map 2 log. They are both roughly 30-100 MPH through 2nd, 3rd and 4th gears. I couldn't get the car to stay in one gear to do a single gear log, as it kept short shifting on its own, even in manual mode. Map 1 feels great and is a huge improvement over stock. Map 2 feels the same and isn't any quicker than map 1, per my acceleration timings. I'm assuming that's because we only have access to 92 here. The first log is map 1 and the second log is map 2.
Car: Evo VIII
Default 01-04-2022, 01:58 PM
Both logs look good.
Default 01-04-2022, 02:05 PM
Awesome! Thanks for taking a look so quickly. So, map 2 looks good, even without 93? I was able to run map 2 on 92 with my Forte GT as well.
tymwalk tymwalk is offline
Car: 2021 Mazda CX-5 Turbo Carbon Edition
Default 01-07-2022, 11:01 AM
The logs look good. Turn off traction control in manual mode to eliminate the kickdown switch. It will hold in a gear with the traction control off.
Default 01-07-2022, 03:16 PM
Awesome! Thank you guys for taking the time to look over them. I also didn't know about the traction control trick, so thank you for that as well.
Default 02-21-2022, 08:08 AM
I decided to upload two proper 3rd gear pulls with the traction control off this time. Just for piece of mind. Thank you very much.
Car: Evo VIII
Default 03-15-2022, 05:05 PM
Still looks solid. 🏎️
