Having some issues with the boost struggling to stay on target. FF seems to be consistently higher than the WGDC so my though would be to lower the Duty Cycle for each RPM range or reduce the FF under the Adjustable Setting's since it seems to be lowering on its own after each run anyway.
- Pure Stage 2 Hi-Flow Twin Turbos with 2" inlet
- High Flow Relocation 2" Inlets
- JB4 with MHD back-end flash
- ER Charge Pipe & Tial BOV
- Custom Intake and Air box
- RB PCV Valve
- AR ******* *********
- N55 Midpipe
- Berks Race Axle Back
- Improved Racing High-Flow 185F External Thermostat
- NGK 97506 2-Step Colder Spark Plugs
3.5 Bar TMPA sensor on order, but stock TMAP still installed.
The first log seems ok, but the second run after shifting to 4th, it seems like there is a struggle to adjust the boost and it kicks me into Map4.
