hitmanfighterz hitmanfighterz is offline
Car: BMW 135I
Default After 5k rpm JB4 goes to map 4 - 12-27-2021, 12:15 AM
I have a 135i N54 just done my Valve cover due to a crack and then my injectors to index 12 I did buy use :/. My 135i is FBO stage 2 lpfp, 2 step colder spark plugs, charge pipe with tial bov, 7.5 step intercooler and ********. I just started to run in to this issue where my car Lose boost after 5k rpm and goes to map 4 I thought maybe to much E85 so I stopped with E 60 and back it down to e45 to hopefully it goes away. But didn’t I ran one solid pull then back to the same drop down to map 4 I have 2 logs from 3rd gear 40mph to 6,400k rpm. if someone can look at it and give me some advice Bc at the moment I’m lost
@HitmanFighterz
George Felix
2009 BMW 135I
FBO
Stock turbos
Jb4
VoIPNerd's Avatar
VoIPNerd VoIPNerd is offline
Car: 2011 335is
Default 12-27-2021, 07:22 AM
Your trims are maxed out and you're running lean. Are you running the E85 back end flash?
2011 335is E93 with DCT
JB4 G5 ISO * BMS DCI * VRSF 7.5" Competition FMIC * VRSF dp's * VRSF Chargepipe * VRSF Inlets * Turbosmart Raceport BOV * Fuel-it Stage 2 Bucketless LPFP * Fuel-it Flex fuel kit * Phoenix Racing Port Injection manifold w/ 750 cc Injectors and BMS JB4 PI Controller * RB Turbo External PCV w/ plugged headports and Mishimoto OCC * NGK 2-Step Colder Plugs * MHD Flex-fuel BEF
Car: BMW 135I
Default 12-27-2021, 08:46 AM
No I am not only bef I’m running is for the burbles which came with the car
@HitmanFighterz
George Felix
2009 BMW 135I
FBO
Stock turbos
Jb4
Default 12-27-2021, 11:37 AM
Update your firmware and put all your user adjustment settings back to the default values.
As stated...you need to lower ethanol content to E30 or load the E85 BEF.
Car: BMW 135I
Default 12-27-2021, 01:43 PM
To update the firmware I can do that straight from the jb4 app correct and with the E85 BEF where do I find that?
@HitmanFighterz
George Felix
2009 BMW 135I
FBO
Stock turbos
Jb4
VoIPNerd's Avatar
Car: 2011 335is
Default 12-27-2021, 02:36 PM
Correct, and there is a sticky thread on everything you need to know about the BEF at the top of the N54 forum on this site. Or here: N54 MHD Back End Flash Maps - N54Tech.com - International Turbo Racing Discussion
Car: BMW 135I
Default 12-27-2021, 05:19 PM
I flashed the E85 map and updated the software but where would I go to reset all to default values?
@HitmanFighterz
George Felix
2009 BMW 135I
FBO
Stock turbos
Jb4
Default 12-27-2021, 05:24 PM
They are listed in the sticky for the JB4.
E Series N54 JB4 - N54Tech.com - International Turbo Racing Discussion
Car: BMW 135I
Default 12-28-2021, 10:25 AM
So it seems way more powerful then ever before here’s an updated log I did this morning. I did leave the value for the N20 sensor and the boost safety wheres it’s at. Please let me know if it’s looking good
@HitmanFighterz
George Felix
2009 BMW 135I
FBO
Stock turbos
Jb4
Car: Evo VIII
Default 12-28-2021, 10:52 AM
Log looks pretty good, please make sure to enable 6 cylinder timing.
Car: BMW 135I
Default 12-28-2021, 01:47 PM
I’m guessing that the 6-cyl timing logging (0-6)? And I would put 5 for IJE0S
@HitmanFighterz
George Felix
2009 BMW 135I
FBO
Stock turbos
Jb4
Default 12-28-2021, 02:00 PM
Yes, 5 if your are IJE0s
