-J- -J- is offline
Car: 335i e93 n54
Default Just done the BEF log review please. - 05-10-2020, 03:27 PM
Hi, could some cast their eyes over this please. I've just done a BEF and would like to ensure all is well.
Thanks in advanced.
J
Default 05-11-2020, 09:46 AM
Enable 6 cyl timing
Also provide a bit more detail on your setup (fuel etc)
From what I can see, doesn’t look bad
-J- -J- is offline
Car: 335i e93 n54
Default 05-11-2020, 01:58 PM
Thanks Dave, I really appreciate your reply.
How do I enable 6 cyl timing?
I’m currently stock bar *********. I’m in the uk so fuel is 99ron. I did the race fuel BEF as that was what seemed to be recommend while I was researching. Was running map 5 before BEF hence map 5 log there. Although today I found map 2 much better, so I’ll log that, once I know how to enable 6 cyl, And report back for you to look over again if that’s ok?
Default 05-11-2020, 10:24 PM
User adjustment settings & then choose the appropriate value for your dme
