vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default Diff lockdown kits available for E and F chassis $150 + s/h - 02-24-2015, 11:07 AM
Non M differential lockdown kits available for E and F chassis
fits both large and small differentials
plate is 6069 aluminum
bolts are 10.9
bushing is 6069 aluminum with polyurethane sleeve
spherical adjustable link
No affiliated with any other manufacturer, designer, company...
$150 + s/h
If interested please send me PM. Thank you!
e46m3to335i's Avatar
e46m3to335i e46m3to335i is offline
Car: 2015 F22 M235i
Default 02-24-2015, 11:35 AM
Do you make these or did you buy it from someone? Just to confirm this is E90 specific or does is fit other models as well?
-Nick
2014 335i xDrive / Silver / ZF8 / M-Sport / 400M / BM3 2H Map / xHP Stage 3 / ATM FMIC / H&R Sports / VRSF **/CP
vwetish's Avatar
Default 02-24-2015, 11:52 AM
Is custom made, I don't buy them. It will fit e87 since the subframe is the same. The f22 definitely no since the subframe is different.
Car: 2015 F22 M235i
Default 02-24-2015, 12:00 PM
Cool. Just wanted to confirm. So in reality it will fit any E9x or E8x since can fit both utilize the same rear sub frame and small/large diffs ? Looks like a nice kit with quality components.
-Nick
vwetish's Avatar
Default 02-24-2015, 12:05 PM
-Nick
Thank you Nick, I really appreciate that!
Levan-i's Avatar
Levan-i Levan-i is offline
Car: 2007 BMW 335i E92
Default 02-25-2015, 03:56 AM
It looks good!
can you help me to get or give me link where to get the bushings?
I already have diff lock and looking for diff bushings as im experiencing heavy wheel hop,
only diff lock didnot help, unfortunately
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
Levan-i's Avatar
Default 02-25-2015, 03:57 AM
oh sorry i've just noticed there is only one bushing for the holder
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
vwetish's Avatar
Default 02-25-2015, 05:37 AM
Originally Posted by Levan-i
It looks good!
You can get bushings from here:
http://store.langracing.com/mounts-and-bushings/
http://www.whitelinesuspensionparts....eries+E90+2008
However, could be your tires, your rear shock or the spring.
There a lot more parts that could induce wheel hop.
Levan-i's Avatar
Default 02-25-2015, 05:38 AM
thanks a lot!
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
vwetish's Avatar
Default another photo - 02-26-2015, 05:38 AM
I have 2 pre-made but able to take orders for more...
4doorbmwpower's Avatar
4doorbmwpower 4doorbmwpower is offline
Default 02-27-2015, 06:06 PM
you have my attention.
vwetish's Avatar
Default 03-02-2015, 07:56 AM
I have 2 available
vwetish's Avatar
Default 03-03-2015, 08:00 PM
Ddang06 Ddang06 is offline
Car: 335i coupe 6MT
Default 03-03-2015, 10:43 PM
Does this serve the same purpose as the Devi lockdown kit?
vwetish's Avatar
Default 03-04-2015, 05:30 AM
Yes, it does.
vwetish's Avatar
Default 03-11-2015, 05:43 AM
I have 1 for large diff available.
vwetish's Avatar
Default 03-13-2015, 07:57 AM
I have 1 for small diff available
vwetish's Avatar
Default 03-16-2015, 05:44 AM
vwetish's Avatar
Default 03-18-2015, 05:39 AM
I have 1 for small diff ready.
vwetish's Avatar
Default 03-20-2015, 12:10 PM
Fast335i's Avatar
Fast335i Fast335i is offline
Car: 07 BMW 335i
Default 03-21-2015, 03:24 PM
What exactly is this for. is this used in conjunction with an LSD?
2007 BMW 335i...M2 exhaust...Macht Schnell DP's...VRSF 7" FMIC...MM Performance inlet system.....VRSF Chargpipe with Tial BOV....MFACTORY LSD....MHD e60. ***** tunING.........RB Stealths......N20 Tmap upgrade.....Steve Stage 2 450......H&R Race lowering springs...MT ET Streets 265/40/18 rear.....NGK 5992
vwetish's Avatar
Default 03-21-2015, 06:55 PM
Add 4th mounting point and spots wheel hop. Work with OPEN and LSD differentials.
vwetish's Avatar
Default 03-25-2015, 05:05 AM
http://www.e90post.com/forums/showpo...5&postcount=18
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 03-25-2015, 06:33 AM
Oh hey look, someone blatantly ripped off half of the Defiv Lockdown kit design!
Robert's Avatar
Robert Robert is offline
Car: bmw
Default 03-25-2015, 06:51 AM
If the original kit was affordable there would be no market for these. But unfortunately that's not the case And it's precisely the reason why I ordered one !!!
2008 e92/MHD ***** E85/Alpina TCU /RB Inlets/MMP Outlets/Vrsf DP/Helix FMIC/Forge DV/BMS CP/DCI/Fuel It st2/TBI/TC Kline/Swift SA coils/MF lsd/Hotchkis sway bars/M3 front and rear links/ Diff LDK/AKG Race subf/diff bushings/Megan toe links /TSW18 forged Nurburring/Mich PSS 245/265 /BMW(Brembo)M perf 370mm BBK
