Default Introducing our Fuel-FIT! line of fuel fittings. - 01-21-2016, 09:25 PM
Hey all, some of you are already starting to see our new line of fittings show up on some of your fuel kits so we thought we'd formally introduce them to you all. Attached at the bottom of this post is a short video showing the differences and how to install them.
As you can see at this time we have four specialty fittings that replace all the stock fittings but retain the same functionality, only better. In addition we added the custom 3/8" fitting to incorporate the ethanol sensors.
Name:  Fuel-FIT! fittings.jpg
Here are a few of the features that all of our fittings utilize.
  • Billet aluminum construction
  • Hard anodized
  • E85 compatible
  • Compatible with -6an push on style clampless hose
  • Better flow potential with tapered transitions and larger passage ways
In addition to the above features our female 5/16" and 3/8" fittings also incorporate:
  • Dual locking feature
  • Dual o-ring design
  • Open design to verify proper installation
In the process of designing these one of our primary goals was to eliminate the flare fittings that are typically required to adapt a quick connect fitting to a barbed fitting. Those fittings are bulky and with the new design we eliminate the potential for leaks.
blisstik's Avatar
blisstik blisstik is offline
Car: 2007 E92 MOTIV 750
Default 01-21-2016, 10:21 PM
Steve: for Stage 3 LPFP guys, without the FPR, is there any advantage to upgrading the OE fuel line? Is it necessary?
MOTIV750 / MHD+JB4 / ADV / SB REAR O2
omarmarji's Avatar
Car: n54 335
Default 01-21-2016, 10:55 PM
+1 great question
751WHP 688WTQ
JP Works Kit Record
SOLD: E90 335i 751whp 688WTQ
johnmaps johnmaps is offline
Car: beemer
Default 01-21-2016, 11:02 PM
I am using Stage2 and upgraded my stock fuel line at the same time.
idratherbesurfing's Avatar
idratherbesurfing idratherbesurfing is offline
Car: 06 STI
Default 01-22-2016, 04:58 AM
Im not sure if the new line are actually bigger diameter or just higher quality material. But for the prices hes charging for all his kits its a brainless choice to upgrade. ....mine should arrive today hopefully before Snowmageddon on the east coast. Lmao
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 01-22-2016, 07:15 AM
Hey Steve,
Are these fitting for use w/ the upgraded lines? Or is anything on the actual 3+ bucket upgraded?
Tony@VargasTurboTech's Avatar
Tony@VargasTurboTech Tony@VargasTurboTech is offline
Car: Anything with a Turbo
It think it would be cool to see 3/8" males as well. That way people can increase line size, and still use the Quick Disconnects. With the 3/8" you will get close to the same flow a s -6 fitting without the hassle.
Vargas Turbocharger Technologies
Tony@Vargasturbo.com
www.Vargasturbo.com
Making the world happier one turbocharger at a time
Default 01-22-2016, 08:16 AM
When buying one of our port injection kits, it's literally only $40 ($60 for F-series) to upgrade the feedline all the way back to the tank. We definitely recommend doing that for both simplicity and flow.
http://www.fuel-it.biz/e-series-port-injection-options/
http://www.fuel-it.biz/f-series-port-injection-options/
Originally Posted by jyamona
Hey Steve,
Yes, they are for use with the upgraded lines. None of them are being used in the tank at this time.
Those are coming along with a couple other products that I'm sure you'll like.
FTR, the stock lines are a little smaller than 5/16" and there are a couple restrictions along the way. Now we eliminate those but still maintain the stock connections at the filter and the HPFP and that was why we developed these.
3000GT MR's Avatar
3000GT MR 3000GT MR is offline
Car: 09' 335i
Default 01-22-2016, 07:22 PM
Whats the pricing and availability?
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust
335i 2009 e90 665RWHP VFF900 ST RIP .
Car: 06 STI
Default 01-22-2016, 10:08 PM
His website is updated
3000GT MR's Avatar
Car: 09' 335i
Default 01-23-2016, 07:39 AM
I still dont see them. I see them as part of kits but not individually.
Default 01-23-2016, 10:25 AM
dotCEO's Avatar
dotCEO dotCEO is offline
Car: 08' BMW 135iM
Default 01-23-2016, 12:10 PM
Fantastic video Steve, I haven't dabbled with Fuel yet as I run Pump94/15% 116oct but I want to step up my fuel'ing if recommended. I'm still pretty new to the whole everything, but do you think I should be looking at upgrading Fuel'ing when E85 just isn't an option for me?
Pardon my ignorance in advanced.
7DCT 2013 LeMans Blue BMW ///335is (Pending Inspection)
6AT | 135i ///M Sport - CRASHED (TOTALLED)
Default 01-23-2016, 12:18 PM
We aren't selling them individually at this time. That's coming but we're waiting on the second batch to come in before we offer them directly to the public ala cart.
Default 04-06-2016, 01:41 PM
In our quest to keep improving and innovating we have started incorporating another one of our new Fuel-Fit! fittings in our Port Injection kits. These eliminate 3 more of the AN threaded fittings from our kits so now instead of there being up to 8 additional threaded fittings in those kits, we are down to 1 at the fuel rail. This greatly reduces the risk of leaks, over/under tightening, and we've adjusted the angle to better accommodate the transition to the HPFP and PI! Just like the rest of our fittings we have also optimized size and flow characteristics for the AN6 lines we use in all of our kits.
Here's a couple comparison pics of the old Y fittings and the new Y fitting installed.
Name:  New y fitting comp.jpg
Name:  Old y fitting comp.jpg
rocky335i rocky335i is offline
Car: e92 2007 335i
Default 08-05-2016, 08:38 AM
I need a short 5/16th fitting where can i order
Default 08-05-2016, 11:15 AM
Pretty sure they already took care of you correct?
Thanks,
Steve
Car: e92 2007 335i
Default 08-05-2016, 11:59 AM
Thanks,
Steve
yea i got it thanks
Default 08-05-2016, 12:02 PM
This is awesome. Keep up the good work folks.
N54 | Build Thread
Bullet's Avatar
Bullet Bullet is offline
Newb
Car: 2008 335i
Default 09-29-2018, 12:16 PM
Where can I order these fittings at?
evl335 evl335 is offline
Car: 335is
Default 10-01-2018, 05:18 AM
Hi steve please answer my emails thanks....
simon
Car: 335is
Default 10-01-2018, 11:28 AM
fuel-it horrible experience act like children unlike precision race works!!amazing professionalism
