Is it possible that I can buy only upgrade fuel line?
If so I'd like to buy HPFP to the Tank with Ethanol Sensor fuel line without Ethanol sensor and also PI to tank fuel line.
I just installed tank to HPFP with ethanol sensor and 5v/bluetooth analyzer on n54. Connected pin15 to white wire, connected power and ground, checked ethanol input setting in JB4 app and i have no e85 readings. Please help
No i didn't do anything but check mark for ethanol integration inside the app setting. Do i need to set meth to 100 somewhere?
I enabled Future D option bit4 and still no readings.
Description: Adds an external FPR (Fuel Pressure Regulator) and a return line. (This kit is for the CPE/BMS PI kit and requires return line fitting from Fuel-It! installed in your LPFP)
Included:
1. Return line adapter for fuel rail
2. -6an line from fuel rail to FPR
3. Fuelab EFI boost referenced FPR
4. Fuel-It! mounting bracket for FPR
5. -6an return line
6. Boost reference line and tee adapter
ES-7 cost = $340
FFTEC 6466 Gen2, MHD Flash Tuned by *****, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
12.23 @ 118.9mph (RBs)
2.3 60' lol (single pass night, bog shifting)
I have your fuel it ethanol sensor, motive short feed line and BMP PI. I want to upgrade the fuel line from LPFP forward. Which fuel line should I buy? If i get the “other PI” setup will I be tossing the Motive short feed line setup? And I will be able to add your fuel it ethanol analyzer with no problem? Will I need any extra fittings? I bought the analyzer “with adapters”
It’s a Z4 35i
Unfortunately I can 't really advise you on the other components. Our fuel lines come complete and are designed to work with the factory fittings and/or our fittings and components. Trying to piece meal everything together will cause issues so it's not really something we offer.
Thank you
So what is the option for the fuel line “non fuel it PI to tank”?
I’m saying if I lose the motive fuel lines and just use your line to a different PI kit will I be able to hook up the analyzer that was supplied by you with your adapters that come with the analyzer kit?
