TwistedTuning TwistedTuning is offline
Car: 2007 335xi 6MT Sedan
Default 02-23-2016, 11:32 AM
great post.
"Increasing the Area Under The Curve"
Custom Performance ECU Calibration
www.twistedtuning.com
twistedtuned@gmail.com
dh58 dh58 is offline
Default 02-24-2016, 06:19 AM
@Steve could you add to each what ethanol % they are capable of? And which lpfp we'd need for what %?
Default 02-24-2016, 07:55 AM
Originally Posted by TwistedTuning
great post.
Thanks, it's still under construction but we'll have a lot of info in this thread to try and simplify things and answer the most common questions.
We've added more information on that. If you are running E85 you need to run a stage 2 or stage 3 depending your horsepower goals. Stage 1 is not compatible with E85 or covered under warranty for use with E85 by the manufacturer. We see some of those burn up over time when used with E85.
Default 03-18-2016, 05:09 AM
Bumping this since there have been a few questions about running E85 lately.
Also need to continue updating it.
N54QC N54QC is offline
Car: 07 BMW 335i
Default 03-18-2016, 07:19 AM
Hey Steve, was wondering what the advantage was of running the FPR, can a return line fitting be added to my pump easily, and is there a way to setup to view ethanol content via JB4 mobile while still using methanol? Thanks
msport335 msport335 is offline
Car: E90 LCI
Default 03-18-2016, 08:00 AM
i currently have the steve AZ stage 1 pump and run e85 every so often on an e60 tune.
what would be the easiest way to upgrade to the stage 2 ? am i able to swap the 255 for the 450 or do i have to buy the complete setup?
thanks
Default 03-18-2016, 08:55 AM
I'm not sure what pump you have. Are you running a Stage 3 and port injection? If so, what port injection kit is it?
thanks
No, the 255 is run inline with your stock pump. You would need to order a complete Stage 2 as it is a complete plug and play swap for your stock pump (and the 255) that eliminates the need for the inline pump and is E85 compatible.
Car: 07 BMW 335i
Default 03-18-2016, 09:05 AM
I have everything listed in my signature. When I ordered from you at the time, I wasn't planning to go PI so it wasn't really a concern. But now that I have practically every bolt on other than PI, I am now considering it. Just trying to figure out the setup I would need and a better understanding of things like the FPR so when I decide to follow through with it, I will know what I should order.
Car: E90 LCI
Default 03-18-2016, 09:40 AM
My stage one is practically new with a new bucket as well....guess i would have to sell them both off as a complete unit.
the stage 2 comes complete with bucket correct? how much?
Default 03-18-2016, 10:18 AM
Sorry, didn't read the signature. Email us at info@fuel-it.com and we'll get you taken care of. It's not a big deal.
Same thing...email us and we can give you a couple options.
Yes, Stage 2 is complete PnP swap for the stock pump.
DylanB335i DylanB335i is offline
Default 08-23-2016, 10:53 AM
Thanks, I've been reading a lot of mixed results on other forums.
Anthony235's Avatar
Anthony235 Anthony235 is offline
Car: m235i
Default 09-14-2016, 08:32 AM
Does the Stage 2 pump by itself (no PI) offer any benefit? Allow more E content?
F series N55.
Default 09-15-2016, 06:37 AM
It depends on the condition of your stock pump and how well your stock pump is keeping up. However with the F-series, the HPFP is the biggest limitation. In addition the Stage 2 is E85 compatible.
Mixmaster Mixmaster is offline
Car: 2007 335i E91
Default 09-15-2016, 12:51 PM
If installing a stage 2 and wanting to run e40 and e60 fuel do you also need to do the fuel lines?
Default 09-15-2016, 08:42 PM
No, most that are running the fuel lines on stock turbo's do so because they are running an ethanol sensor.
Lnjwtr Lnjwtr is offline
Car: 2013 535i m sport
Default 02-08-2017, 02:32 PM
I just ordered a stage 2 lpfp ( no pi or tbi) for my f10 n55. Can anyone give me just a rough estimate of how much e i can run before the hpfp is maxed out? I realize only logging will tell for sure. Im looking for a ballpark number to start. Maybe e50? I run around e30 on stock lpfp. (4.5 gallons e85 and the rest 93)
2013 535i m sport
Jb4, Fuel it stage 2 Bms intake
ER Chargepipe, Vsrf ********
Anthony235's Avatar
Car: m235i
Default 02-08-2017, 02:44 PM
My understanding is that the stage 2 lpfp alone does not allow you to actually run more E. If I'm wrong I will be a happy camper though
Default 02-08-2017, 05:52 PM
It will be best to log and post those up in the support section. Now that you will be running an E85 rated pump, once you max out the stock HPFP, if you want to run higher mixes, port injection will be the next step.
JazRedGT JazRedGT is offline
Car: 2007 335i E-92 6AT
Default 02-21-2017, 08:04 AM
Do you guys still recommend TBI for a goal of 600whp or naw?
2007 AW 335i E-92 6AT MMP Stage 3 @ 25psi / JB4 G5 ISO / XHP STG3 / VRSF D-Ps / MMP INLETS&OUTLETS / ***** MHD E50 BACKEND / CW EXHAUST / CPe CP / GReddy RS BOV / BMS METH KIT / WAGNER IC / PR STAGE3 LPFP 10.92 @ 132 1.72 60ft 6.96 @ 103 1.55 60ft
bdhh's Avatar
bdhh bdhh is offline
Car: 2008 335i convertible
Default 02-21-2017, 12:32 PM
Quote> (Up here in Canada we do not have access to e85 at all. With that being said our best source of fuel is 94 Octane from Petro Canada.)
Dont forget that our Canadian gas is rated in Ron. US gas is API.
So 94 Ron rating is 91 US at best.
2008 BMW 335i Convertible
ADE Bottom Mount 6062 Single
VRSF Charge Pipe & 7in intercooler Tial BOV,
Ign Project Plasma Coils & grounds
Robs High & low side Catch Cans with
head plugs.
Diff Brace, Fuel it stage 2 & Meth Port Injection
Aquamist HSF-4 Meth injection
Alpina Flash
BMW PE Mufflers
MDH Flash
Line lock & 16in Drag Radials
11.7 ET, 1.8 60ft, 122mph
Default 02-21-2017, 10:18 PM
600 would be the most we would recommend but that would require and low ethanol mix. Straight E85 is going to max out at about 500-525whp with TBI. That will also vary based on target AFR's.
e36luv e36luv is offline
Car: 1998 M3 GT3582R
Default 04-11-2017, 05:51 AM
Need some advice for my goals/setup. I am running a 6466 on 93 only and planning to add meth. What pump should I run to get the most out of this setup. No e85 or port injection for me at the moment.
Default 04-11-2017, 10:51 PM
Stage 2 will be sufficient to max out your HPFP and is a simple plug and play swap.
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 04-11-2017, 11:47 PM
That's actually not true....
Canadian and American fuel is rated in AKI (anti knock index) which is (Ron+Mon)/2, not API whatever that means.
94 octane in Canada varies alot from fuel station brand to fuel station brand, some Canadian 94 acts like US 91. Some act like true 94 and surpass US 93.
Personally I prefer Husky 94.
Mods: Stock for now
Lowon's Avatar
Car: Bmw M2
Default 04-11-2017, 11:48 PM
Hey Steve,
Do you guys offer inline fuel filters? I used to have one that filtered down to something like 1-4 microns.
Thanks,
~Lowon
Mods: Stock for now
