I just did my HPFP as well on my 535i. It took almost exactly two hours and I didn't run into any real problems other than the
Harbor Freight long reach 5mm hex bit socket I had was too long to remove the rear bolt. I had to drive the bit out of the socket with a punch, cut off an inch with a Dremel, and pound it back into the socket. After that it was pretty simple and you can see the bolt head if you look down through one of the manifold openings. It also took a while to unscrew the lower front bolt since you can only get to it with a hex key, at least on the 535i. It may be easier on the 135i/535i.
I do have one suggestion I didn't see in the DIY guide. Put a rag in the front and rear charge pipe connector tubes and everywhere you'll be removing bolts (underneath the HPFP, throttle body, etc.) That way there's zero chance of something falling into one of the tubes and if a bolt falls while you're removing or installing it, it will fall onto a rag and not into the depths of the engine bay.
