steve.kodra steve.kodra is offline
IXLR8
Default Alpina B3 Trans Flash...Done! - 02-20-2013, 08:28 PM
ALPINA SWITCH-TRONIC Sport Automatic Transmission (6-speed)
It is snowing here in Colorado and I can't do much if any testing. I do like the gear indicator displaying the current gear you are in all the time, D1, D2 or S1 S2 etc. When in S mode, I noticed that it takes quite a bit of wheel spin to activate traction control. There seemed to be much less intervention, even when spinning and hopping sideways.
The entire programming process took less than 20 minutes. It took about 10 minutes to program. I then locked the doors and let it sit for about 10 minutes as instructed. The Paddles shifters still function normally as well.
I will give more feedback after the weather clears.
N54mike's Avatar
N54mike N54mike is offline
Car: grocery getter
Default 02-20-2013, 09:02 PM
I'm not sure how this could effect DTC intervention as you didn't flash the DSC or DME..
e90man's Avatar
e90man e90man is offline
N54ever
Default 02-20-2013, 09:07 PM
How does one accomplish this???
N54mike's Avatar
Car: grocery getter
Default 02-20-2013, 09:08 PM
I wanna know what Terry thinks of this.. Terry do you think this has solved the timing flatlining problem? Do you think your trans will survive a bit longer at higher power levels after flashing this?
N54mike's Avatar
Car: grocery getter
Default 02-20-2013, 09:09 PM
http://bimmerboost.com/showthread.ph...Y-using-WinKFP
IXLR8
Default 02-20-2013, 09:43 PM
Not sure either. I am not sure how any of these systems communicate with each other. This was just one of the things I immediately noticed.
Xearo's Avatar
Xearo Xearo is offline
Because Racecar
Car: '08 135i
Default 02-20-2013, 09:46 PM
Just got mine working as well. Was actually rather simple once you realize what youre doing to set it up/flash it.
Mines a 01/08 135i, paddles work fine. Havent really driven it yet, but will get some time tomorrow afternoon to test. If anyone needs assistance, lemme know.
-'09 135i MT - Custom 6466 ST - 680whp
-'08 135i AT - 6466 ST - dead
-'97 318is - Daily
-'82 320i
jordan313 jordan313 is offline
Default 02-20-2013, 09:52 PM
man everyone has done it on the east coast. but the west down here in socal, everyone is a wuss to try it
blackshan blackshan is offline
Car: 335i coupe
Default 02-20-2013, 10:09 PM
Cheers Steve to new mods!!
jb4 G5 fbo w/ mmp inlets and 3.5 sensor
IXLR8
Default 02-20-2013, 10:10 PM
Thank you sir!!
Car: 335i coupe
Default 02-20-2013, 10:15 PM
Your welcome! Hoping to join the upgraded turbo crew later this year! I know u must be enjoying your ride with awd and now some tranny help! Bring on the boost!!
Default 02-20-2013, 10:32 PM
in for updates!
Eleventeen Eleventeen is offline
Car: 2007 335i
Default 02-21-2013, 11:22 AM
Originally Posted by SteveAZ
in for updates!
Love the sig, LOL
2021 Supra A91 Edition
Default 02-21-2013, 11:27 AM
Flash is working great. Faster shifts for sure. It has not changed anything post shift timing related from what I've seen.
335iTT's Avatar
335iTT 335iTT is offline
Car: '07 335i
Default 02-21-2013, 12:24 PM
Hmm- 05/07 production-- check!
Looks like I can benefit from this flash-- anyone around Atlanta area that has tried it successfully?
J
GoofyGuy GoofyGuy is offline
Car: 335xi Coupe N54
Default 02-21-2013, 01:38 PM
Is this alraedy in the software someone just found it, or is there another download outside the software needed? This has me wanting a coding cable finally.
aoschadlin's Avatar
Car: 535i
Default 02-21-2013, 01:45 PM
It's a completely separate piece of software to the JB4 FW or BMS Flash.
Search on the BimmerBoost site and there's some instructions there on getting the file and doing the install.
Good luck!
gordyhda gordyhda is offline
gordyhda
Car: 2008 535xi, Sport pkg, JB4, BMS DCI, 93 Octane
Default 02-21-2013, 02:17 PM
Will this work for 08 535xi?
2016 550i xdrive, 2018 X3 M40i, Collegeville, PA
mykal's Avatar
mykal mykal is offline
Car: '09 E90
I'm waiting to see why 09 and up builds lose paddle shifter function. Then I'm doing this.
pthomas1984 pthomas1984 is offline
Car: E92
Default 02-21-2013, 02:37 PM
i've been trying to find the link to the spdaten file download...can someone help me out...thanks
Bimmer Barney's Avatar
Bimmer Barney Bimmer Barney is offline
Car: 07 E90 335i
Default 02-21-2013, 02:49 PM
Terry, would BMS provide this service? If so how much $?
2007 E90 335i - Sparkling Graphite Metallic - JB4, Mr.5 Intake, VRSF 7" FMIC, RB PCV Valve, BMS OCC, Evolution Racewerkes Sport Oil Cooler, Cyba Intake Scoops and Quad Exhaust Tips, M3 UCA/LCA, 17x9 and 17x9.5 Apex Arc-8
lfelunden's Avatar
Car: 335i e92
Default 02-21-2013, 02:50 PM
I got the B3 Biturbo, gearchanges are MUUUUUUUUUUCH quicker than my 335i..
It feels like it bangs the gears in :D Also, it's hardware is changed when compared to the ZF tranny mounted on the 335i
Default 02-21-2013, 02:53 PM
I won't even confirm or deny I'm personally running this stolen software. Anything I post about it was told to me by a friend.
lfelunden's Avatar
Car: 335i e92
Default 02-21-2013, 02:54 PM
I can post a acceleration clip of it if you want to hear how quick the gearchanges are
Default 02-21-2013, 02:57 PM
Originally Posted by Eleventeen
Love the sig, LOL
Hahahaha...I'm afraid I'm going to come home one day to "an intervention"
On topic...so I've reset adaptions before on the transmission and noticed a difference initially (smoother/faster) but as things progressed those gains were lost. I can see it very clearly in logs after I do a reset (timing is a downward spike as opposed to a flat spot).
So I'm curious as to the adaptions a bit down the road.
2nd, does this have a negative affect on durability? Do you feel it is any more "abrupt" or just faster?
