rowdytn rowdytn is offline
Car: 2019 GLC63 AMG
Default 2019 GLC63 - Ready to try more aggressive maps - 02-18-2022, 02:38 PM
(I posted this in the support and logs group, but realized I probably should have posted here)
For the past year plus, I've been running 93 Octane on Map 2 in my 2019 GLC63 every day. I've never thrown a code, and love how it runs. When I first installed the JB4, I read about issues running ethanol mixes and decided Map 2 was enough and I'd never need ethanol. However, for the past week or so, I've been really getting the itch to try some more aggressive maps.
Can anyone provide me with some suggestions about what mixes and maps to try first? I know George has said some cars handle the mixes better than others. I'd like to see what mine can do, preferably without blowing anything up. My hope is to ease into things, and then add more ethanol to the mix/change maps as the car shows it can tolerate it.
Thank you!
Default 02-20-2022, 09:50 AM
Just start with a few gallons of E85, maybe 3-4, and see how the car tolerates it. Fuel pressure is usually the problem with E85 use in these.
Car: 2019 GLC63 AMG
Default 02-20-2022, 08:11 PM
Thanks, Terry! Would you suggest I run with Map 3 for awhile and then see how it does or if I see any CELs?
Default 02-20-2022, 08:26 PM
I'd start with map2 on an E20 mix and see if the fuel pump can handle it. If so then map3 may work.
