scheib scheib is offline
Default E85 51% - 12-27-2021, 06:50 PM
Wondering if this is common to all pumps in the US? Or do other states have another minimum percentage. I'm south of Atlanta.
2013 BMW 335i F30 6MT PWG - JB4 - MHD - VRSF Charge pipe and Intercooler - BMS Intake
Default 12-27-2021, 07:52 PM
That is pretty common.
Make sure you test the content before you use it, it's likely over 51%
zach1328's Avatar
zach1328 zach1328 is offline
Car: 535i
Default 12-28-2021, 05:52 AM
Very common. I don't know the exact regulations by state, but "E85" typically varies from about 50-83%. As far as I'm aware, actual 85% ethanol at a pump would be very rare to find as 83% is typically the high-end.
As already mentioned - testing is the best way to confirm. Most E85 is likely somewhere in the 70-80% ballpark. Some stations in colder states may get lower ethanol in the winter (50-60%'ish) due to concerns/issues with cold-starts on heavy E85 mixes.
2007 335i - JB4 + MHD BEF, RB Twos Plus, PI + Stage 3 LPFP, BMS DCI, VRSF **, VRSF 7.5" FMIC, VRSF CP w/ TiAL BOV, MMP inlets, VRSF aluminum outlets, XHP Stage 3, TC Kline SA, M3 F/R control arms
2008 535i
N54
