(#226)
Default 05-11-2021, 03:25 PM
Originally Posted by dwitness
Hi im new to this meth i bought a aem kit with soleneoid im wondering if my jb4 can control my setup dont be harsh on me im here to learn ����
In theory you can use any controller you want but I'd suggest ditching the controlling and having our FSB run your pump and solenoid. That allows the JB4 to integrate meth control and safety in to the tuning.
Jaybone Jaybone is offline
Car: 2020 Kia Stinger GT1 AWD
Default 06-01-2021, 07:15 PM
Can someone check my logs with wmi… timing seems pretty bad and I missing something? Denso 5346 .22, borla exhaust, fuel wires connected, bms intakes, and 93 octane gas. terry am I missing something?
grostoine grostoine is offline
Car: Kia Stinger GT
Default 06-01-2021, 07:22 PM
What are you guys running as far as mixture ?
Default 06-01-2021, 07:24 PM
Snow performance boost juice
bhamm bhamm is offline
Car: Stinger GT
Default 06-04-2021, 06:32 AM
How often are you guys purging? It seems like i have to almost every time i want to use it.
First run is today, second is three days ago.
2019 Stinger GT Limited AWD.
JB4 + EWG, BMS Meth Kit, HKS M45iL .24, MBRP Exhaust, Lozic TCU, Mishimoto FMIC, Mishimoto Catch Can, JA Intake Scoops, Tial BOV (TO Come: Johnny Tig Intake)
Klasse Apex Rims 18", Firehawk Indy 500
M&S Rear Diffuser, M&S Type S Spoiler, LED Canards, Carbon Exhaust Tips
Corleone1 Corleone1 is offline
Car: Stinger 3.3
Default WMI is in... - 06-05-2021, 10:06 AM
Name:  WMI is in resize.jpg
Default 06-05-2021, 11:26 AM
You keep your tank filled at all times?
Default 06-05-2021, 11:30 AM
Next thing is an oil catch can as now with meth injection you will get those valves cleaned and an occ will keep it like that!
Car: Stinger 3.3
Default 06-05-2021, 11:36 AM
WMI is new for today but I think I will have met in tank all the time.
KiA Stinger AWD, 3.3, 2018 - white.
JB4
2˝" primary DP,s with 200 cells
Secondary straight
Wagner IC with inlet pipe KN filters
Windboost
BMS Meth with 90/10 mix
ADD catch can
0-60 mph in 3,37 in Dragy log
1/4: 11,70@119 in Dragy log, mild launch, 1,8 60 ft
Mustang conservative Dyno Map 6: 394 hp & 582 nm (428 fp)
Car: Stinger 3.3
Default 06-05-2021, 11:37 AM
Yes, its on its way...
JB4
Secondary straight
Windboost
ADD catch can
Default 06-05-2021, 11:39 AM
Nice which occ did you get?
Default 06-05-2021, 11:41 AM
Do you keep your tank filled all the time?
Car: Stinger 3.3
Default 06-05-2021, 11:51 AM
I buy a tank and let my GTR friend build the OCC. His name is Tony and he is building engines and tune all fast cars is Sweden. He uses a new Mustang dyno. Very conservative. My GTR did show 25% less in Mustang compared to Dynojet but all cars he tunes is faster than other with higher HP. I will dyno my Stinger Soon.
Here is his Insta:
Login • Instagram
Login • Instagram
JB4
Secondary straight
Windboost
ADD catch can
Car: Stinger GT
Default 06-05-2021, 03:05 PM
I am about 1/3 full right now. I have the bigger tank from BMS as well.
Default 06-05-2021, 05:59 PM
Maybe a leak where are is getting into the system?
Car: Stinger GT
Default 06-06-2021, 06:04 AM
Possible. I am not sure where. I am going to switch the BMS injector, right now i am using the bung on the Mishi FMIC. Not sure if that will make any difference. Will do a big purge again too.
Jimboski10 Jimboski10 is offline
Car: 2021 Kia Stinger GT2 AWD
Default 06-09-2021, 07:54 PM
I think I am going to take the plunge and go WMI on my 2021 GT2 3.3 AWD. I have the JB4, PNP, EWG, BMS intake, ARK secondary.
I am trying to determine if there is any type of quick disconnect check valve that might be able to be placed on the liquid lines just past the firewall in the engine bay? I am trying to figure out a way to be able to quickly remove the liquid line, injector in the engine bay so WMI install is pretty much undetectable (assuming all lines are hidden in the interior and using the stealth tank adapter)….and then be able to easily install the gear in the engine bay.
Has anyone done this? Or figure out a way to do this?
Car: 2020 Kia Forte GT
Default 06-09-2021, 08:47 PM
People don't even notice my system installed.
Even the dealer didn't see it and didn't say anything.
I wouldn't even worry about it being discovered.
Bought some black line from AEM directly since they are in Southern California (Gardena) and got it the next day.
2020 Kia Forte GT
6 Speed Manual
JB4+Bluetooth Connect
Whiteline Springs
13.77@103
Map 7, E30+WMI, Hoosier Drag Radials
E85 Station Locator (US Only)
Default 06-09-2021, 10:13 PM
You will like the meth kit it works well!
Default 06-10-2021, 05:23 AM
Thank you…black line? What are you referring to…I thought the kit came with everything?
Default 06-10-2021, 05:29 AM
When you buy the system from Burger Motorsports it comes with clear line.
I wanted to hide the water-methanol better and since I didn't buy the kit from Burger (I bought a BMW system used off Facebook Marketplace) and didn't want to reuse the clear line that came with the used system, I ordered black hose/line from AEM.
I only used the FSB from the used system so it cost more going that route, I don't recommended it.
2020 Kia Forte GT
6 Speed Manual
Whiteline Springs
13.77@103
Default 06-10-2021, 05:47 AM
Makes sense…thanks!
Car: 2020 Genesis G70
Default 06-15-2021, 09:27 AM
Went to install the WMI stealth plate today on my G70 and it does not appear the mounting points line up with the bold welded into the trunk. Am I just an idiot and cant figure it out or is there an fitment issue with the G70?
Default 06-15-2021, 09:48 AM
Not sure if that is designed for the G70 trunks? Its says 2018+ Stinger might want to check with BMS
Default 06-18-2021, 12:21 PM
Hey guys, what additive lever are people running with E30? I did 50, 55, and 60 and timing a AFR still look good
