(#201)
sch4400 sch4400 is offline
Car: 08 535i
Default 11-10-2016, 07:52 AM
Is it possible that I can buy only upgrade fuel line?
If so I'd like to buy HPFP to the Tank with Ethanol Sensor fuel line without Ethanol sensor and also PI to tank fuel line.
v.i.335is v.i.335is is offline
Car: e92 335is
Default 12-10-2016, 12:49 PM
This may be a stupid question, but can this work alone without the jb4 just the sensor the analyzer and a Bluetooth compatible device..
erichale's Avatar
erichale erichale is offline
Car: 335i coupe
Default 12-10-2016, 04:43 PM
Are you planning on coming out with a stage 4 pump soon?
Default 12-11-2016, 12:10 PM
We have our new Platinum LPFP being released, we just need to get them up on the website and will be doing an announcement.
Here's a brief video overview and a sample log...
mbanks21 mbanks21 is offline
Car: 2015 335i
Default 12-22-2016, 07:47 PM
I'm interested in being able to view ethanol content only on my JB4 F series, am I missing the link on your website?
Default 12-24-2016, 12:39 PM
Her you go...
http://www.fuel-it.biz/f-series-235i...ensor-upgrade/
Iaintslow's Avatar
Iaintslow Iaintslow is offline
Default 11-04-2017, 03:24 PM
I just installed tank to HPFP with ethanol sensor and 5v/bluetooth analyzer on n54. Connected pin15 to white wire, connected power and ground, checked ethanol input setting in JB4 app and i have no e85 readings. Please help
Default 11-05-2017, 06:13 PM
Did you set your meth scaling to 100?
Iaintslow's Avatar
Default 11-05-2017, 07:44 PM
No i didn't do anything but check mark for ethanol integration inside the app setting. Do i need to set meth to 100 somewhere?
I enabled Future D option bit4 and still no readings.
frmtl2_335i's Avatar
frmtl2_335i frmtl2_335i is offline
Car: 07 e92 M/T
Default 03-11-2018, 09:57 AM
are these still available? i do not see them in your website
ES-6
Attachment 35917
Description: Replaces stock line from filter to the HPFP
Included:
1. -6an line from filter to the HPFP
ES-6 cost = $105
ES-7
(Picture coming soon)
Description: Adds an external FPR (Fuel Pressure Regulator) and a return line. (This kit is for the CPE/BMS PI kit and requires return line fitting from Fuel-It! installed in your LPFP)
Included:
1. Return line adapter for fuel rail
2. -6an line from fuel rail to FPR
3. Fuelab EFI boost referenced FPR
4. Fuel-It! mounting bracket for FPR
5. -6an return line
6. Boost reference line and tee adapter
ES-7 cost = $340
FFTEC 6466 Gen2, MHD Flash Tuned by *****, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
12.23 @ 118.9mph (RBs)
2.3 60' lol (single pass night, bog shifting)
Default 03-11-2018, 11:20 AM
That is really old and much has changed since then.
An ES6 kit is "HPFP to tank"
http://www.fuel-it.com/e-series-135i...ensor-upgrade/
FPR kits are available as an add-on for our PI kits or if you already have one of our PI kits, you can email us and request an invoice.
TrapHouse TrapHouse is offline
Car: Z4 sDrive35i
Default 02-11-2021, 06:27 AM
I have your fuel it ethanol sensor, motive short feed line and BMP PI. I want to upgrade the fuel line from LPFP forward. Which fuel line should I buy? If i get the “other PI” setup will I be tossing the Motive short feed line setup? And I will be able to add your fuel it ethanol analyzer with no problem? Will I need any extra fittings? I bought the analyzer “with adapters”
It’s a Z4 35i
Default 02-11-2021, 09:19 AM
Unfortunately I can 't really advise you on the other components. Our fuel lines come complete and are designed to work with the factory fittings and/or our fittings and components. Trying to piece meal everything together will cause issues so it's not really something we offer.
Thank you
Car: Z4 sDrive35i
Default 02-11-2021, 09:57 AM
Thank you
So what is the option for the fuel line “non fuel it PI to tank”?
I’m saying if I lose the motive fuel lines and just use your line to a different PI kit will I be able to hook up the analyzer that was supplied by you with your adapters that come with the analyzer kit?
Default 02-11-2021, 05:15 PM
Yes you can order that complete kit, you just won't be able to order a partial kit and it won't work with the MOTIV line.
