I haven't been as active on the forums lately... YouTube and Instagram are where I post most of my content now. If you aren't already subscribed/following there, you're missing out
That being said, I have exciting news I want to share! I took the car to the drag strip after doing a ton of modifications (listed below). My previous best was 10.90 @ 136mph with full interior, stock diff, stock axles and radial tires. I did a bunch of weight reduction, upgraded my diff, axles, suspension and tires and went back to the strip. Results below:
1st pass (20psi): 11.29 @ 128mph with a 1.94 60ft
2nd pass (25psi): 10.53 @ 137mph with a 1.73 60ft
3rd pass (28psi): 10.36 @ 134mph with a 1.59 60ft
The old record for a manual N54/N55 with stock BMW chassis was 10.70 @ 135mph, but I'm now the fastest after beating it by almost half a second! Yes, Ghassan Automotive went 9.6 but they have a custom back-halfed drag chassis. I think I can run 9's as the car was misfiring during my 10.36 pass.
The car has made 752whp and 691wtq at 30psi. Being at ~28psi with a misfire, I'd guess it was making ~700whp on this pass. Log attached.
so this is with no custom tune. Just a jb4 with the jb4 back end flash for single turbo with e85 with port injection
is this right?
2007 e90 335i
pure stgae 2 DD turbos, rb inlets, bms 4 bar map sensor
Jb4 with mhd hybrid e85 back end flash, vrsf down pipe vrsf 7" intercooler, vrsf charge pipe with tial bov and afe intake. Fuel it stage 2 pump and fuel line/ethanol content kit.
spec stage 2+ clutch with new oem dmfw
is this right?
Believe he has a custom BEF.
However, our BEF is pretty well sorted. I ran 10s in my xi a bunch on our OTS hybrid PI bef & pures. Took maybe 3-4 passes to dial in for 1/4
Also, nice work sir. Love the thoroughness of the write up (per usual, lol).
Keep killin it!
is this right?
Just replied to your same comment on 1Addicts. This is a custom ***** tune as someone commented. But like Dave mentioned, the BMS/JB4 BEF is very good and I've also ran multiple 10 second passes with it.
Keep killin it!
Thanks Dave!
Good **** Jake !
Watched the video last night. Your girl was happy too
