(#651)
matthewo matthewo is offline
Default 02-03-2017, 07:11 AM
yeah but why?
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 02-03-2017, 10:20 AM
Originally Posted by matthewo
I just bought a used kit an installed it and have been running it a little while.
I have noticed on my logs when it sprays my trims per bank are way different.
I log both trims and avgign as trims so I can see both banks, before I installed the kit they stayed pretty much the same, now I am having 25-30 difference in it, like trims may be richer like 10-15 area and avgign trims I assume this is bank2 is reading 35-40
I need to adjust my fuel scalar a little for tip in, but I hope I don't have to adjust the fuel scalar per bank, I can only assume its getting uneven distribution but not sure why...
Originally Posted by hunting11s
that's exactly what's happening.
I had this issue for over a year. Bank 1 went super negative and Bank 2 was always very positive during a pull. Turned out I had a bad injector # 6.
Before:
http://***********/u/fmonteiro444/12-...ata=2-23-25-26
After replacing bank 2 injectors:
http://***********/u/fmonteiro444/1-1...-26&zoom=24-65
dh58 dh58 is offline
Default 10-28-2017, 09:23 AM
Before:
http://***********/u/fmonteiro444/12...ata=2-23-25-26
http://***********/u/fmonteiro444/1-...-26&zoom=24-65
I have similar issues and mods to you.
Basically everything is the same except these 4 things:
- Stock turbos not RBs
- xHP not Alpina
- Trebila flash not *****.
- It's a 135i
Have some questions for you..
Did you replace all the injectors or just injector 6?
Did you do anything else?
Have you got this sorted out now? And is it reliable?
Are you still on ***** tune?
Thank you!
