Car: 09 E92 SG
11-13-2015, 10:32 AM
Originally Posted by Rob@RBTurbo
LOL. Damn the luck!
Well if it is any consolation I do think these will still work on the angled style, but a true angle style charge pipe should be a much nicer and cleaner fit. So just going to make one and there will be 2 options.
Good man!
11-16-2015, 06:51 AM
LOL. Damn the luck!
Arnt the vrsf intercooler a 3" inlet so these won't work with them anyway? At least not without more modification
UK V8Bait Tuned
Built Motor
TD Turbo 335i
Car: e92 335xi
11-16-2015, 06:57 AM
This is what I was wondering. The 7" VRSF openings were much larger than the 5" ETS it replaced:
Stalker
Car: 335I
11-16-2015, 07:45 AM
Honestly do not know as I do not follow VRSF at all. If someone can measure it we can confirm, but it certainly looks bigger.
Car: 2007 e92 335i
11-16-2015, 07:52 AM
VRSF is 3in inlet and outlet. AMS is the same way.
Stalker
Car: 335I
11-16-2015, 07:55 AM
99% sure I have a customer doing an install on our Super RB EVO's who has the AMS, and if so his anyway is 2.5" (standard).
But yes, these were not designed around 3". 2.5" is such a tight squeeze 3" must be real fun to install ha.
Car: 2007 e92 335i
11-16-2015, 08:14 AM
I'd double check with that specific customer.
AMS prided their intercooler as being the first with "revolutionary" 3 inch inlet/outlet end tanks. I also have an AMS intercooler and can confirm mine is 3", which is why it came with reduction couplers to mate with the 2.5" stock plumbing, just like VRSF.
Look forward to hearing about an install on a 3" intercooler. Hopefully it's not too much of a bear.
07 E92 335i 6MT- BMS JB4 G5 ISO, BMS Meth Kit with dual CM7's, MMP inlets/outlets, AMS FMIC w/ custom 3" Lower CP, N54 Tuning ***, BMS CP, MHD, PE Mod Exhaust, 4" tips, Vibrant 1792's in place of secondaries, BMS OCC, N20 TMAP, RB PCV, BMS CDV Delete, BMS Clutch Stop, BMS/Shifteck SSK, BavAuto Weighted Knob, 335d intake, 335is Engine Mounts, E46 M3 Tranny Mounts, Redline Mt90 & diff, 1/4 BOV barb, OEM Aero Lip, CSL Trunk Spoiler, Painted Side Markers, Angel Eyes, Enkreuz H10R 19in Wheels, coded.
11-16-2015, 08:23 AM
I'd imagine we will have to cut the Hot side CP high up and use an ally coupler to mate it to the vrsf/ams reduction coupler. I'm sure it will work just more clamps and that's exactly what I wanted to do away with
UK V8Bait Tuned
Built Motor
TD Turbo 335i
Stalker
Car: 335I
11-16-2015, 09:50 AM
Well agree that clamps in these areas are horrible, BUT being silicone you could use a more permanent pinch style clamp (that does not require servicing) and still have the compliance to get around in there. The only other option is to make a 3rd option for 3", which COULD be easily done if we can justify that there is demand. Maybe we will just knock out 2 birds with 1 stone and make an angled 2.5" and an angled 3".
Car: e92 335xi
11-16-2015, 09:51 AM
I am pretty sure VRSF is 3", I did not measure it but it was obviously larger than the ETS opening. I would have signed up for this GB but was waiting to see about fitment.
Stalker
Car: 335I
11-16-2015, 09:57 AM
No worries on the Group Buy. Quite frankly I am very burnt out on Group Buys.
Just an update though, we will have these in the 2.5" "Straight-up/Straight-in available for shipping this week. Once they are in hand we will put that particular offering up for sale.
To come:
2.5" Angled
3" Angled
Thanks,
Rob
Car: e92 335xi
11-16-2015, 10:09 AM
To come:
2.5" Angled
3" Angled
Thanks,
Rob
Excellent. We're getting dumped on with snow here so the likelihood of me getting to install these (or my RB inlets which look awesome BTW) anytime soon is nil. I barely had time over the weekend to replace a bad front axle + LCA before the storm hit, won't be doing any logs for a long while. Except the kind that go in my wood stove
Brendan
Car: 335i 2007 6spdman
11-16-2015, 01:34 PM
Blank. Wrong thread
11-16-2015, 08:04 PM
Let's get some dyno numbers!!!
11-17-2015, 09:37 PM
Any updates?
Stalker
Car: 335I
11-18-2015, 04:10 AM
Update is 3 posts up.
Car: 2009 BMW 335i Sedan
11-18-2015, 06:01 AM
Would love to see how the 3" will look like once you have them in..
Us AMS FMIC guys struggled with the hot side coupler being too short
And slipping off
Stalker
Car: 335I
11-18-2015, 06:30 AM
And slipping off������
It will look the same but a bit bigger in diameter at the merger towards the intercooler.
Car: F06 N55 640i Gran Coupe
11-18-2015, 06:59 AM
Any chance will this fit into a E89 Z4 2009 RHD?
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS DP n FULL Custom Exhaust
Custom BC forge 18/17 set up
Stalker
Car: 335I
11-18-2015, 07:19 AM
They should fit the Z4 (RHD or LHD), using the same techniques as discussed throughout this thread for the install.
The biggest hurdle (for all models/drivesides/etc) is differences of interface at the Intercooler connections which comes with the numerous aftermarket offerings that exist. We are going to try to cater to the vast majority of the interfaces in due time, see above discussions on all of that.
I believe the only N54 option that could pose an install problem with the current design is the 5 series, as it has its own distinctive charge pipe design. But time will tell.
Thanks,
Rob
11-19-2015, 07:06 AM
Thanks,
Rob
Sounds good, I will put in the order for both hot & cold inlet soon. Thanks!
Stalker
Car: 335I
11-19-2015, 07:12 AM
Sounds good.
UPDATE: We now have 6 of the 2.5" (for Straight-down/Straight-in Intercooler) option in stock. If anyone is interested please let me know.
Thanks,
Rob
11-19-2015, 09:16 AM
Sounds good.
Thanks,
Rob
I'll wait for the 3" angled version rob
UK V8Bait Tuned
Built Motor
TD Turbo 335i
Car: 09 135i
11-19-2015, 11:21 AM
Sounds good.
Thanks,
Rob
I'm ready to make payment. ..... How much will it be shipped to 00956 ,PR ????
Car: '10 335i
11-19-2015, 11:57 AM
As will I, 7" FMIC VRSF
