(#76)
Aridk Aridk is offline
Car: Bmw 335i e92
Default 03-14-2014, 03:15 AM
Great looking car and nice vid's, but please make one where we can hear the exhaust now with the dp, thx
4rose's Avatar
4rose 4rose is offline
Car: M135i
Default 03-14-2014, 10:23 AM
Car looks insane and that power..... Jealous for days
Jason @ BMS's Avatar
Jason @ BMS Jason @ BMS is offline
Administrator
Car: M340i,X5,Raptor,C7 ZR1
Default 03-17-2014, 10:57 PM
After driving Terry's F10 M5 I noticed that the steering wheel had a split in it you could see through. My 4 Series did not. The M5 paddles were also different. I ordered all the parts and installed everything in my 435i. The steering wheel looks great. The M5 paddles however did not work on the 435 but I will get back to that on another date.
You need to have paddles to do this M5 steering cover mod or you will have holes in the back of your wheel where the paddles are supposed to go.
Part numbers for the front and back plate for the M5 to F32 wheel conversion:
DECOR TRIM COVER STEERING (front) 32307846029 $153.75
COVER FOR STEERING WHEEL (back) 32307848270 $43.82
GuMMiBaEr's Avatar
GuMMiBaEr GuMMiBaEr is offline
Car: F31 328XI N20 03/2013
Default 03-18-2014, 01:01 AM
Nice mod! Did this already in my 328xi!
You have to use the control modules from your old paddles.
You can use them with the new M5/M6 paddles. Then it will work!
F31 | 328XI | N20B20A | 03/2013 | JB4 Stage 2 | Map 2 | FF Wires | 4" DP | Wagner Comp FMIC | Pipercross drop in | OCC | KW V2
Bid assistance in Germany for troubleshooting, coding, alpina flash, ecu tuning etc.
Administrator
Default 04-11-2014, 09:50 AM
Thank you for your advice in the private message. I was able to take the paddles apart by sliding the little pin out and swapping the electronics like you said. Works and look great.
GuMMiBaEr's Avatar
Default 04-11-2014, 02:22 PM
No problem Jason!
But did i´m looking good?
Didn´t coded away the boring BMW Logo in your instrument cluster? The performance logo looks so much greater!
Sayitaintso Sayitaintso is offline
Car: 435i
Default 04-22-2014, 09:10 PM
Hey Jason,
Did you have any issues with paint adhesion when painting your reflectors? I'm having a tough time....I'll try some plastic primer and try again.
Administrator
Default 04-23-2014, 03:16 AM
Originally Posted by Sayitaintso
Hey Jason,
I didn't use primer. I sanded them with a fine sandpaper. I also sanded the raised letters down. Then painted them. Then clear coated them. Don't go too thick with the primer and make sure you let them dry well before putting them back in.
You can also always buy them pre-painted.
smahel smahel is offline
Car: 335Ci
Default 04-27-2014, 11:11 AM
Hey Jason,
have you installed OCC ? Where?
Administrator
Default 04-28-2014, 12:54 PM
Originally Posted by smahel
Hey Jason,
There is no OCC installed on my 435i.
We have rigged them up to the F series N55 engines for testing and have found that the engines run clean and have little oil blow-by. Even after thousands of miles of brutal testing on race gas. Nothing in the cans. So we decided not to make a OCC kit for F series N55 engines. When they get older we'll reevaluate. Now the N20 is another story.
iuhutch's Avatar
iuhutch iuhutch is offline
Car: 2011 e92 335xi
Default 04-28-2014, 03:51 PM
How did you handle the airbag?
Administrator
Default 04-28-2014, 07:00 PM
To remove the airbag you must first unhook the negative terminal on the battery. Failure to do so will cause an SRS airbag light appear on the dash.
Then you put a screwdriver through the little holes on the left and right of the back of the steering wheel and unhook each side of the BMW airbag. The screwdriver will go in at an upward angle. The clip/release mechanism works like a safety pin. The airbag will pop up a bit on that side when you press the screwdriver in. Pull the airbag straight out and unhook from the wheel. Unplug the black connector on the wheel and pull the airbag straight out. Make sure no wires or anything is in the way when reinstalling the airbag. I recommend taking a photo of where everything is before you take the wheel apart.
Car: 335Ci
Default 04-29-2014, 01:47 AM
O.K. Thanks.
So my OCC from E92 is useless...
Administrator
Default 08-11-2014, 03:39 PM
A lot has changed on the 435i since my last post in this thread and will post pics of the mods as I take them. Among other things I just upgraded the turbo to a Pure Stage 1 and it's been great. Here is the post for those not following it. http://www.n54tech.com/forums/showth...highlight=pure
The BMS 435i was also featured in Bimmer Magazine and was also mentioned in European Car magazine in the "No Fly Zone 4" article.
Newguy123's Avatar
Car: 12' 135i
Default 08-11-2014, 04:19 PM
dude thats badass! congrats jason!! i just got my car back from a pure upgrade as well...what a difference!
18’ Glacier white RS3
#PURETURBOS
#FUELIT
Administrator
Default 08-23-2014, 10:05 PM
Thanks! I have been enjoying the Pure turbo and it's great sound.
I recently added some OEM BMW carbon fiber goods and a pair of carbon fiber side vents from a manufacturer here in California.
OEM BMW Carbon Fiber Side Mirrors.
I was pretty positive they would look good and it was an easy choice.
Install: Make sure the mirror glass is straight. Then put something flat and thin under the mirror and pry outwards to remove the mirror lens. Be sure the pry tool does not scratch the mirror housing. Then disconnect the 2 small lens heater wires. The factory mirror cover pops out from the inside if I can remember correctly. You have to bust off some small tabs for the CF cover to go in and the CF covers come with torx screws so they fit in nice and snug and wont be whistling. The factory mirror glass just snaps straight back on.
OEM BMW carbon fiber rear spoiler.
It is so light you can't believe it. I have never seen a spoiler this light. I thought the box was definitely empty when they handed it to me. This spoiler took about 5 days to get used to after I installed it. I rested it on the trunk and for a few days and kept taking it on and off and still was not sure. I went for it and now love it. I really wanted to paint it but was talked out of it.
Install: I purchased the Betalink glue in the tube kit from the dealer and glued the spoiler to the trunk just like the ACS roof spoilers I have had in the past. It had double sided tape under it but I don't trust it. I used thick blue painters Tape to hold it down for 24 hours while the glue dried. i didn't drive the car for 2 days either.
They were both purchased at Bob Smith BMW parts dept. in Calabasas, CA where I purchased the car.
I also got the OEM BMW performance carbon fiber license plate frame. This is very nice and very lightweight.
Aftermarket OEM Side Vent refinished in real carbon fiber.
I got these from a guy right here in California and love them.
http://www.ebay.com/itm/BMW-F32-4-SE...4d7ab4&vxp=mtr
Install: I used a plastic body panel puller to pry the factory vents off. I busted off the tabs on the factory side vents when removing them. If you are extra slow and careful removing them maybe you will have better luck. The carbon fiber replacements just clicked in after I transferred the puffy insulation sticker foam from the factory vent. I think this is to prevent vibration and make them fit sung. Again be carful peeling this off and transferring it.
Newguy123's Avatar
Car: 12' 135i
Default 08-23-2014, 11:43 PM
Looks tits man nice work!
#PURETURBOS
#FUELIT
4rose's Avatar
Car: M135i
Default 08-24-2014, 10:51 PM
Looks the bomb
iuhutch's Avatar
Car: 2011 e92 335xi
Default 08-26-2014, 08:37 PM
Incredible car! Wow miswell bought an m4 tho, no?
Peter @ Pure's Avatar
Car: F20 M135i
Default 08-27-2014, 01:15 AM
When will you install meth?
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Administrator
Default 08-27-2014, 12:45 PM
After I install my ER F chassis intercooler and test it. The Er charge pipe is in with bungs so it is meth ready!
http://www.burgertuning.com/F_chassi...oler_FMIC.html
Newguy123's Avatar
Car: 12' 135i
Default 08-27-2014, 01:51 PM
Suhweeet! I should be getting my ER fmic tomorrow
#PURETURBOS
#FUELIT
Car: F20 M135i
Default 08-28-2014, 01:12 AM
Cant wait till you get that installed and run the meth kit on your car
peter@pureturbos.eu
pureturbos.eu
M-terkait's Avatar
M-terkait M-terkait is offline
M-Terkait
Car: F30 335i
Default front brakes - 08-28-2014, 08:59 PM
are these Mperf rotors or you swapped for something else?
N55 - Doc race 6266.
rustyminded rustyminded is offline
Car: Bmw 328i F30
Default 08-29-2014, 06:59 AM
This is Great Jason, tell me updates what is dyno number gains !!
F30 328i - 8 auto.. JB4+FF+EWG, OCC, Injen Intake+scoop, AFE dp, AA axle-back - H&R springs, H&R rear SB - Front Strut - F&R BMS spacers..
