Car: M5, Z4 3.5 IS
12-18-2012, 07:03 PM
Originally Posted by Ocean
Map 1 has max boost of 13 psi. Map 5 will autotune up to 16.5 psi. You be the judge.
Well, 16.5 > 13. However, is there concern about stress on the components, wear and tear, etc? JB4 is the only thing I plan on doing to the car. Is the idea that map 5 learns from what you have?
Sorry about the noob questions, but I got a feeling that searching through the 120 some odd pages in this thread alone will bring up more questions than answers.
And finally, has anyone done a this to a Z4?
Car: 535i
12-18-2012, 07:54 PM
Map5 will autotune for the best performance for the mods that your car has.
Stress on components has more to do with how you drive the car.
And yes there's a few active posters on here who have done this to a Z4. I *think* even to an 35is version?
Cool stuff no longer installed.
Car: M5, Z4 3.5 IS
12-18-2012, 07:57 PM
Glad to hear it. Hoping it will get here in time to be a Christmas weekend project.
Car: 08' 335xi
12-18-2012, 09:05 PM
The stand alone SLD can be used. The CPS/SLD module must be removed.
Thanks Terry, I have the CPS/SLD so it looks like I'll have to remove it. Got a 2F4F Vehicle speed, plausibility code today from this.
2017 BMW M2 in Mineral Gray
DCT Transmission & Executive Package
Speedtech Stg 3 (8374) l BM3 Jordan Tuned l AA Intake l ER Chargepipe l ER FMIC l Stage 2 LPFP l EOS Pump Controller l XDI-35 HPFP l NGK 97506 l Ohlins R&T l SPL Suspension Parts l RE-71 R’s l BMW M Performance Kidney Grills, Mirror Covers, Spoiler, Rear Valence l Full PPF Wrap l 35% Tint l
Car: 07 335i Coupe
12-18-2012, 10:35 PM
I just ordered my JB4 w/ USB cable and DCI. It should be here by Friday afternoon. I'm hoping for a smooth install. I have one main question and I have done numerous searches and haven't found an answer and its almost impossible to read every single page on here. I'm curious exactly what the JB4 does other than raise the boost. I'm assuming it can advance timing and change fuel trims. Is that right? I was more used of knowing about an S-AFC where the user would make those kinds of changes. I guess instead the JB4 does it all for you unless using map 6 I believe you can make a custom map.
Thanks,
Lance
Car: 2007 335i
12-19-2012, 12:47 AM
Thanks,
Lance
I can't answer your question. However, having just installed my JB4 and DCI a week ago, let me assure you that you are in store for a serious OMG-OMG-OMG gigglefest. Seriously. Map5 is your friend. Welcome to the dark side.
Car: bmw 335i e92
12-19-2012, 08:47 AM
Easiest way to find out is to log it and send to Terry. It has been 1monthnif thinking and researchin wether its map 1 or 5. Then finally i logged it then sent to Terry. He said to go map 1. My mods are jb4 g4, bms dci, sprint booster and *** delete.
Even its 13psi but it goes freakin fast and maintains it!! Vs stage 3 mk6 golf gti? SMILE:D
_______________________________________\\\
BMW 335I E92 2007 RHD 6AT,FULL M3 BODYKIT,HYBRID TURBOS,BMS ADAPTER W/ 3.5BAR TMAP,VTT INLETS,JB4 G5ISO W/ MHD TREBILA FLASH,BMS ANTI-LAG,AEM METH KIT W/ FSB,BMS DCI,VRSF CHARGEPIPE & TIAL BOV,VRSF C@TLESS ***,FMIC,BMS OCC,BMS CABIN FILTER,MUFFLER CUSTOM BULLET,97RON PUMP GAS
Car: 07 335i Coupe
12-19-2012, 05:42 PM
I believe it. I already get an adrenaline rush as it is. I can't imagine how much better its going to feel. I guess next will be down pipes and meth/water injection to be able to run some more boost. I'm assuming the timing should automatically advance itself depending on what octane and meth/water combo I'm running.
Car: 2008 BMW 335xi Sedan
12-20-2012, 02:16 PM
Quick question - new JB4 user. I've figured out most of what I need to know but I am confused about one thing in particular.
When I go to set the 4/4 or 4/5 Can Flap setting... after I set to 4/5 for example... the guages sweep to odd positions. What should they do after I hit volume down when I have the speedo at 4 and the tach at 5... pushing volume up or down should set that setting... no?
I'm just wondering what should happen after I hit volume down to select that setting... what do the guages do?
Sorry if I'm not making any sense.
Probably being sarcastic
Car: e46 323i & e90 335i
12-20-2012, 03:10 PM
Reset your gauges to your car, you may be selecting the incorrect options. These is directions to do this in the jb4 printout
200k mi 99 blk 4dr e46 m52 323i w/ h&r's k&n cai shark'd
95 e36 m3 s50 5spd stg2 turner re11a's autox toy lol
07 BSM 6spd e90 n54 335i jb4 g5 iso ar dp's SPEC 2+ w/ SMFW BMW ssk bms dci RB pcv 455lph lpfp 50% e85 Syn. BOV hijk lmnop
94 e34 530it 290k 350ci sbc tko600 project
Car: M5, Z4 3.5 IS
12-21-2012, 12:18 PM
Sorry if this has been answered. I just ordered my JB4. It arrived yesterday. I understand that it's a G5 board. My car is a '11 Z4 3.5 IS. I downloaded the 12/14/2012 Interface. Questions:
1. Did it come with, or without the ISO firmware. (Sorry, I've yet to install it)
2. Which option am I selecting from the settings? 2 (G4 N54 w/BMS Flash, 1M, or 335is), 5 (G5 ISO), or 6 (G5 ISO w/BMS Flash, 1M, or 335is)
3. Which gauge metric should I use?
Thanks,
Jerry
2011 S Drive 3.5 IS
2008 M5
2006 Mini Cooper S JCW
12-21-2012, 12:32 PM
Correct, the DB9 positions are different so it's no longer compatible with the G5. The good news is SLD wires are only $10. Or you could salvage wires from your SLD/CPS harness.
12-23-2012, 12:00 PM
I've got an 08 335xi sedan. JB4 G5 ISO and Burger DCI. No other mods. I'm curious....does anyone know what kind of HP I probably have running map 1 with this setup?
Car: 535i
12-23-2012, 03:31 PM
It's a really hard question as it depends on so many factors. Altitude of test, ambient temperature, model of dyno, miles on your car, quality of fuel blah blah blah.
Build some logs and have a play with this software. http://www.bradbarnhill.com/projects/VirtualDyno/
A number of people on here use it and feel it gives a pretty accurate representation. At least for knowing where you're car is at now and what new mods do to the power output.
12-23-2012, 06:40 PM
This is interesting! Thank you for the link/info. I will definitely play with this. I want to know what I've got.
Car: 2008 535i
12-23-2012, 09:40 PM
Here's my info a while back, hopefully it will give some idea
Same modz before the G5 board
JB4 G4 and DCI ONLY with E85/91 ( Cali, 79 F and Terry running my car )
12-23-2012, 10:38 PM
I'm just running 91 octane and map 1. Any idea how much difference? I'm obviously still learning and appreciate the info. Thank you!
12-23-2012, 11:11 PM
Thanks,
Jerry
I'm in the same boat here
It's a little frustrating to be honest - it's like the answers are here in the forum but you have to go digging for them.
As a non tech guy its hard to play catch up and some clear instructions would be a great help.
Using the interface I've managed to find out what firmware date mine is but don't know how to find what the date of the current one is and where to download it from.
12-24-2012, 03:25 PM
Car runs fantastic....too. gonna do some pulls and post.
Car: bmw 335i e92
12-24-2012, 06:48 PM
Hey wut do u guys think if i paint my wheels white? Will it look good? As i hv 5spoke?
12-24-2012, 08:22 PM
Wrong thread for that question. Search for other cars with the same style or start a new thread and I'm sure a few people would have some good input.
Super Demigod
12-25-2012, 12:27 AM
Stays at the lagfix value. Unless boost somehow manages to get over 5psi before you get to your FUA setting, in which case you'd get a funky boost oscillation.
I've written the next version of the code that does away with the FUA setting and instead correlates it to lagfix. Just need to test it now. If anyone is bored and interested email me.
So this surge I feel during part throttle after the transmission upshifts is a known issue? When pedal is like 10-20, it drives fine, but when It's 25-40 or so, it surges. Please delete this post if this feedback is in the wrong place.
Car: bmw 335i e92
12-25-2012, 04:21 AM
Hehe its alldone now.. Did supra silver colour more less than the ones i hv now but brighter :D
Car: 335xi Sport
12-25-2012, 07:56 AM
Merry Christmas ! Terry, Best Wishes for you and the family!
Uggg....I didn't get anything for my car this Christmas except car cleaning supplies and some Weathertech mats... I just downloaded the 12/14 firmware and will track through the snow and play with my car this morning while my 3 daughters play Just Dance 4.....
2013 335i M-Sport - 6MT - Not too many mods.....Yet !
Car: M5, Z4 3.5 IS
12-25-2012, 02:45 PM
Just installed mine. Took about an hour and a half. No major issues, except that the big connector is a PITA to slide back on. The firmware had the /2 making it a G5, so I went with option 6. The gauges seemed to be good right out of the box and Map 1 was already set. Made a couple of menu selections (CanFlap On, Boost on fuel, etc). Will switch to Map 5 later tonight and do some "learning pulls". Doing red line runs in 3rd in the middle of the day on Christmas is probably not a good idea anyway. Gonna try to schedule a dyno for next weekend and see exactly what kind of numbers we are looking at.
P.S. The latest firmware is in the first post.
2011 S Drive 3.5 IS
2008 M5
