joeinsd joeinsd is offline
Car: 2010 e92 335i msport
Default N54 checking in - 08-19-2019, 12:07 AM
Hey all,
Just threw on new plugs and looking for a quick look-over to make sure things are alright. I’ll update firmware at a later time.
Logs attached. Thanks in advance!!
Default 08-19-2019, 12:06 PM
Overall looks "ok"- some corrections across multiple cyls & a little dip up to
Fuel? Which plugs?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 08-19-2019, 11:33 PM
4gal E85, rest 91.
NGK 95770/5992 plugs gapped to .022.
Anything I could do to help the timing?
Default 08-20-2019, 08:27 AM
Originally Posted by joeinsd
4gal E85, rest 91.
add another gal. of e85
If that doesn't help timing- may want to close the plug gap a little bit more.
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 08-20-2019, 04:39 PM
Sounds good. I'll give that a try. Thanks as always, Dave!
Default 08-21-2019, 11:22 AM
No worries- keep us posted : )
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 08-29-2019, 10:30 PM
I started misfiring on cyl6... Not sure why. I don't fully understand logs (which is why I'm here asking for help), but to me it looks fine up until the misfire. Bank 2 seems to lean out as soon as I hit 4th. However, I can't see anything leading up to it.
I know the logs aren't from ideal pulls, but these are the times I actually caught the misfires.
Default 08-31-2019, 10:43 PM
Bump. Thoughts, anyone?
Car: 2008 E93
Default 08-31-2019, 11:20 PM
What gap currently ? What coils ? What index injectors ?
Default 09-01-2019, 06:45 AM
Misfires are generally ignition related.
Pull that coil pack & move it to a different cylinder- if it follows, replace the coil
e92 AT 335xi 2.0
Doc Race Kit 6062
