LiamPage LiamPage is offline
Car: 2011 Bmw 335i
Default N55 2ef3 Code - 08-18-2019, 06:13 PM
I have a 2011 335i jb4. So on map 2 i was only hitting like 12 psi i contacted bms and they said i need to cut the diode and update to iso. So i did that and now im hitting like 17psi on map so which is no good considering its targeting 14 psi. Anyways a few days after I updated i got a misfire code 2EF3. I replaced the plugs that dident fix it. I swapped the coil to a different cylinder that dident fix it. Misfire stayed on the same cylinder. Then today i just did the injector and that did fix it earthier.... Not sure what else i can do. Any options would be greatly appreciated
Default 08-20-2019, 08:34 AM
Log?
misfires are generally ignition related- coils/ plugs being pretty common
does it happen on a lower map as well?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2011 Bmw 335i
Default 08-20-2019, 01:06 PM
Thanks for replying. I will try to get a log tomorrow and yeah i also tried on map 1 and 5 and and keep getting the same code.. When checking codes in jb4 it takes like 15 mins of driving the the code to actually be shown
Car: 2011 Bmw 335i
Default 08-20-2019, 01:24 PM
Log?
OK here is a log i did a week ago it was getting the same code here as well but this was before i changed plugs and did the injector
Default 08-21-2019, 11:43 AM
do you have a current log? A log from last week won't help much- Ideally would like to see now.
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: 2011 Bmw 335i
Default 08-21-2019, 04:49 PM
YYeah sorry i had to wait to drive the car but i just did this log
Car: 2011 Bmw 335i
Default 08-21-2019, 04:51 PM
I forgot to click upload heres the log
Default 08-26-2019, 11:14 AM
This log doesn;t look bad- how did the car feel?
e92 AT 335xi 2.0
Doc Race Kit 6062
