Secondchance Secondchance is offline
Car: Kia Stinger GT LTD
Default map 3 logs ( lemme know if they look good please ) - 07-30-2019, 12:32 PM
Let me know how this looks please. Making sure 3 is fine before moving up to 5.
18 GT LTD. K&N intakes, Denso plugs, borla CB, jb4 map 3. e30 mixture
thanks in advance
davidjc70 davidjc70 is offline
Car: 2019 Kia Stinger GT2
Default Map 3 Logs - 07-31-2019, 04:04 PM
Just ran Map 3 too. There are two logs but I can't remember which one of the two was the one I ran from a launch. If you could take a look and let me know if everything looks ok I would really appreciate it.
Thank you!
Default 07-31-2019, 05:29 PM
thanks in advance
Looks OK to me!
Thank you!
Give me a longer run to check it out.
Default 07-31-2019, 05:59 PM
Looks OK to me!
thanks Terry
Default 07-31-2019, 06:08 PM
What's the best way to provide a run? Off a launch to a certain speed and hold? Or can it be another way to get it done?
Default 08-02-2019, 12:23 PM
thanks in advance
Hey man! What sort of runs did you do for your logs that you attached here?
Default 08-04-2019, 08:35 AM
Hopefully these are what you may need. Try to perform a longer run. I did two of them. If you need anything different from this please let me know.
Thanks in advance!
Default 08-18-2019, 06:25 PM
Terry any insight on these? Want to make sure Iím running ok.
Thanks so much!
Default 08-29-2019, 08:17 AM
Hi Terry! I ran a more recent Map 3 run. Could you please take a look at this one? It's a bit longer as well so hopefully this will suffice. Interested to see if everything is looking good.
Thanks again for all of your help!
