DamnDatsun's Avatar
Car: 2010 135i msport
Default 6466 single turbo logs+ question. - 08-14-2019, 03:48 PM
I just installed a 6466 precision turbo on my n54. I got the kit used, so I'm not sure on the waste gate spring psi.
Map1 shows about 16psi. When I switched to map 2, boost spiked at ~17 psi. So, assuming everything was going as it should, I switched to map 3. But, boost will not go above~18 psi.
With the car off, I can hear the Mac solenoid clicking then the gas pedal is 40%-60%. The solenoid doesn't click with the pedal "floored". Any ideas or advice? Thanks for your time.
File Type: csv 1565822790745_0_2019-08-13 17_15_59_Map-2.csv (13.3 KB, 20 views)
Default 08-15-2019, 11:10 AM
Which flash did you load?
Can I see a map 3 log?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
DamnDatsun's Avatar
Default 08-15-2019, 03:03 PM
I used the jb4 single turbo the map. Non e85
I attached a map 3 CSV file.
Default 08-15-2019, 09:40 PM
Set duty bias to 50 across board & relog
e92 AT 335xi 2.0
Doc Race Kit 6062
DamnDatsun's Avatar
Default 08-17-2019, 04:47 PM
Duty bias @ 50
DamnDatsun's Avatar
Default 08-18-2019, 04:13 PM
My jb4 settings
Default 08-19-2019, 11:52 AM
Set DWP to 80
Bump DB to 60 @ 4k to redline.
e92 AT 335xi 2.0
Doc Race Kit 6062
DamnDatsun's Avatar
Default 08-19-2019, 03:18 PM
Map 3 with dwp and db adjusted.
Side note, I've done the Mac solenoid test suggested by y Terry on a YouTube video I found. Car ignition on but not started, Mac solenoid clicks at part throttle but not at WOT.
Maybe it's just in my head but the car feels quicker on the part throttle range where to the solenoid clicks, than it does on WOT.
Appreciate the help with trouble shooting.
Default 08-20-2019, 08:30 AM
Let's try bumping your FF up- lets try settting that at 80-100, and let's see if boost goes up / you hit target.
What springs are you using in the WG?
e92 AT 335xi 2.0
Doc Race Kit 6062
DamnDatsun's Avatar
Default 08-20-2019, 03:38 PM
With FF set to 100, I was able to pretty much reach Target of 20psi on map3.
I switched to map4 to see if there new FF setting would let me reach that target psi also. Unfortunately no. I'm hitting ~21 psi with a target of 23psi.
Attached are CSV files for maps 3&4.
File Type: csv 1566340254320_0_2019-08-20 14_57_29_Map-3.csv (9.7 KB, 21 views)
Default 08-21-2019, 11:22 AM
Bump FF up to say 110 for map 4- keep an eye on fueling.
e92 AT 335xi 2.0
Doc Race Kit 6062
DamnDatsun's Avatar
Default 08-21-2019, 06:15 PM
That adjustment got me up to 22.6psi in map 4. But my high pressure fuel pump dipped to 9 so I think I'll step back to map 3. Thanks again for all of your help!
I attached a map 4 log.
Default 08-22-2019, 07:40 AM
Yeah- it looks like your biggest limit now is fueling
If you want help dialing in map 3- let me know, but it seems like you have a pretty solid handle on it.
e92 AT 335xi 2.0
Doc Race Kit 6062
DamnDatsun's Avatar
Thumbs up 08-22-2019, 08:13 AM
I'm definitely open to any suggestions you have for map 3.
Default 08-22-2019, 10:39 AM
can i see a log of map 3 w. the updated FF?
e92 AT 335xi 2.0
Doc Race Kit 6062
