Soprano890925 Soprano890925 is offline
Car: 2014 335
Icon1 Log Review - Troubleshooting CEL & Hesitation - 03-03-2022, 05:10 AM
Good Day
I have been experiencing a few issues with EWG N55. Issues listed:
- Hesitation in any gear and mode:ECO. Comfort, Sport
- Drivetrain malfunction: with the following errors:
+118001 Mixture ECU: mixture too lean
+120308 Boost Pressure Lower than expected
+108F01 Boost Pressure Lower than expected
The issue started about 200Km's after I used some octane additive (used multiple times prior).
Car currently has the following mods:
VRSF DP
Aluminium chargepipe
JB4 + running stage 5
I recently changed the spark plugs and ignition coils.
Please see review my log and advise me
1. What the potential issue may be
2. What are items for concern as shown by the log
F30 EWG 335
VRSF DP
Aluminium ChargePipe
JB4
Last edited by Soprano890925; 03-03-2022 at 05:13 AM.. Reason: Did not attach the log
Car: Evo VIII
Default 03-03-2022, 11:08 AM
Please record another log at full throttle and map 0. Thanks!
Car: 2014 335
Default 03-03-2022, 11:31 AM
I will re-log and post the results here.
The issue, I am experiencing causes the car to throw the drive train malfunction when pushing beyond 4krpm
F30 EWG 335
VRSF DP
JB4
Car: 2014 335
Default 03-03-2022, 12:10 PM
Please see new log attached
On Map 0
Car sputtered alot and eventually stalled.
F30 EWG 335
VRSF DP
JB4
Default 03-04-2022, 11:47 AM
Sputtered and stalled? That's not going to be JB4 related, especially on map 0. I don't see anything in the log that would cause that since HPFP, trims, AFR's ect. look good.
However boost is below target, maybe a boost leak, or ???
Car: 2014 335
Default 03-04-2022, 01:04 PM
I haven't checked for a boost leak.
Perhaps the better description I should have used is surged...similar to a misfire, but no codes indicating misfires.
Only codes are showing that I'm running lean.
Could my lpfp possibly be dying
F30 EWG 335
VRSF DP
JB4
Default 03-06-2022, 08:04 PM
Rail pressures looked fine so I don't suspect and LPFP issue. Sounds more like a boost leak.
Car: 2014 335
Default 03-06-2022, 08:59 PM
Thank you
I will look into it ASAP.
Thanks alot
F30 EWG 335
VRSF DP
JB4
Car: 2014 335
Default 03-24-2022, 11:18 PM
I have uploaded a new log after addressing my boost leak.
Determined that the boost leak was coming from 2 places on the chargepipe
1. The rubber boot connecting the pieces together (had to replace)
2. Where the CP connects to the intercooler
Please check the attached logs and advise me if everything looks healthy.
F30 EWG 335
VRSF DP
JB4
RVA_N55_Fan RVA_N55_Fan is offline
Car: 2014 435i
Default 03-25-2022, 06:56 PM
You will need to run a full log per the necessary instructions before they can provide feedback.
2016 435i M-Sport EWG MPPK Manual 6, BMS Map 6 BEF-PS2-Race, Pure Stage 2 turbo, Spool-FX150 HPFP, Walbro 535 LPFP, BMS Intake, BMS FMIC, BMS BOV, 3.5 TMAP, ER DP, AA CP, FTP Turbo Inlet, H&R Sport Springs, BMW 335is clutch kit, BMS Clutch Stop, BMS Diff Bracket, BMS Wheel Spacers, BMW SSK, BMW Track Package
