Ayrton70 Ayrton70 is offline
Car: Mini Cooper S2021
Default WMI setting Mini F56 2021 - 03-12-2022, 02:20 PM
Hi everyone, I kindly ask you if you have a manual or simply an explanation of all the items on the APP jb4 regarding the WMI section, I have just assembled the system and I do not know the meaning of the various parameters.
Thank you
Default 03-14-2022, 10:54 AM
Not too much to it.
Set boost additive to 50 to start
Set signal scaling to 60
Set min flow boost to 8
Then do a log on map 3 and post it to this thread for review.
Default 03-15-2022, 04:29 AM
Hi Steve, and thanks for your support!
attached you will find the log, keep in mind that I used 95 RON petrol, you know where I can find a manual that describes the functions of your wmi, there are many parameters and I would like to know them
I forgot to enter the wmi flow, what other parameter do you need?
I also have a problem with the wmi flow it remains never goes to zero, it always remains between 8 and 15, what can I do? I connected the blue cable to the AEM 0-5v flow sensor
Thanks for the help
Default wmi log - 03-15-2022, 04:31 AM
log gasoline 95 ron
Car: Evo VIII
Default 03-15-2022, 12:29 PM
Log looks good, your trims are maxing out but you are not going into any sort of lean condition, just something to keep on mind if you end up in any place that is significantly colder.
Default 03-16-2022, 01:52 AM
Thanks for your help!!
the wmi display never goes to zero, it stays between 12 and 8, do you know how I can fix it?
