(#251)
Default 11-09-2018, 03:59 PM
FWIW the last few shipments of tuners we've been including the latest SENT software. I've yet to trigger the IAT fault on our development car over the last few weeks with it. So hopefully, that's one bug down.
Default 11-09-2018, 05:38 PM
Originally Posted by Bvanni
Has anyone used Map 5 with E85 yet. I'm curious how it's working for everyone? Can the stock fuel pump keep up?
Its advised to stay below E35 at this point. I doubt the fuel system will manage neat E85.
2021 VW Golf 8 R
Bvanni Bvanni is offline
Car: B9 S4
Default 11-09-2018, 06:38 PM
That’s what I figured.
Just to make sure before I do this. The car has a 15.3 tank if you mix 10.2 gallons of 93 and 5.1 gallons of E85 you will have E35 at 97% octane. Which will be safe to run as long as you go into settings and switch to ethanol kit; correct?
Default 11-10-2018, 05:23 AM
Sounds right. On the JB4 you don't need to set anything. Just make sure the fuel plug is connected. All maps can be used with a ethanol mix as the Fuel open loop setting is global.
2021 VW Golf 8 R
Nez136 Nez136 is offline
Car: Audi S4
Default 11-12-2018, 08:07 AM
Didn’t throw any codes for a while. Launched the car on map 5 the other day and the Christmas tree came on at let off. First time in a few weeks.
Took a road trip to the packer game yesterday and when I was just cruising on my way back the drive system malfunction came on. First time that’s happened since week one I believe. Was on map 3. Original SENT chip, latest firmware. I’ll definitely try the new SENT chip of you guys are still sending them out.
Car: Audi S4
Default 11-12-2018, 08:11 AM
Also just curious as what the stock boost is on this car? I’m trying to gauge the target boost on each map and it seems a few guys are hitting 20+psi way more consistently than I am.
Email Terry for the chip.
Did you maybe get a screenshot of the faults?
2021 VW Golf 8 R
Car: Audi S4
Default 11-12-2018, 08:19 AM
Will do,
And I did not, when it was happening the first week or so it was always the same codes which ranged from
6E33
5E7E
Or 8A4D
8176
233F
Then my old code log showed a
2800 once in a while.
Typically the codes most consistently thrown have been 6E33 5E7E and 233F
I do have a AWE switch path with remote for the valves if that has anything to do with a few of those.
Default 11-12-2018, 08:47 AM
Will do,
6E33
5E7E
Or 8A4D
8176
233F
The first two could be exhaust value related and the others are indeed IAT so get the chip and lets see.
2021 VW Golf 8 R
TEKNIKA's Avatar
TEKNIKA TEKNIKA is offline
Car: 2018 AUDI RS5
Default 11-23-2018, 06:48 PM
Hello, good evening and belated Happy Thanksgiving. I am new to the forum and the world of JB4. However, I will be testing the JB4 on my 2018 Audi B9 RS5. I have scheduled the installation tomorrow, but I wanted to perform my due diligence in some research prior to installation.
Firstly, I hope I am in the correct thread for a B9 RS5 installation?
If I am lost, could someone point me in the right direction of the installation guide?
The only seemingly appropriate installation guide I have found is: "https://www.n54tech.com/flash_files/audi_s4_install.pdf"
I plan on providing data, feedback and any other pertinent information tomorrow and as often as possible. Also, I will be scheduling baseline and post-JB4 dyno power curves in the coming weeks. Thank you BMS for allowing me to be a part of this JB4 R&D for the B9 RS5 and I hope my platform and I will be a useful and informative member to BMS and the JB4 community.
Default 11-23-2018, 10:18 PM
If you need help email George@burgertuning.com.
TEKNIKA's Avatar
Car: 2018 AUDI RS5
Default 11-24-2018, 09:55 AM
Thank you Terry. I will definitely do that if needed.
So, I just had the BMS JB4 installed on my 2018 B9 RS5, updated the firmware to [AUDI_JB4_SENT_T7.hex] and immediately tested on MAP#3. My "butt dyno" definitely noticed a significant difference in power!
I was able to drive approximately 20 miles from Audi North Orlando to home and noticed no codes, CELs or any other anomalies. Of course, I will update should anything arises during the course of daily driving and testing.
I did however experience intermittent app disconnects along with the app gauges freezing during logging. Is there something that I could be doing to trigger this or is this a known issue? I noticed the app froze and disconnected when I minimized the JB4 app, but I have not done it repeatedly yet to test if this is an always true case. I am currently running the JB4 Mobile on an iPhone 7 Plus with iOS 11.4.1.
I was able to record a few logs, but due to app disconnects, I am struggling to determine which were recorded under stock settings or under MAP#3. I have noticed a variation in boost ranging from 21-24 psi under WOT.
I was able to record what looks like a pull that allowed me to get to 4th gear and 120mph under WOT, but I am uncertain if this was stock or MAP#3. Based on the "butt dyno" it felt like a MAP#3 log. Thank you in advance for any assistance and insight.
by T3KN1KA
Default 11-24-2018, 10:25 AM
by T3KN1KA
There is more to see in the log than in the picture. Shoot the csv over by email and we can work on the connection issue etc as well via email.
2021 VW Golf 8 R
TEKNIKA's Avatar
Car: 2018 AUDI RS5
Default 11-24-2018, 10:34 AM
Hi George. Thank you for the reply. Log file sent sir!
Default 11-27-2018, 07:09 AM
A user put up some results from his stock SQ5 on 93 and map 3. Even though he got a better launch on the stock (see G's) run it still shaved close to .5sec off the 0-60mph.
2021 VW Golf 8 R
kanemari kanemari is offline
Car: Audi S4 B9
Default is it ready? - 11-29-2018, 06:59 PM
Hi Guys - Ive been following this thread for months. Want to drop the hammer and buy a JB4 to swap out for my DTUK box, but dont want to be waiting around for new chips / hardware changes or what not since I live outside the US.
I guess what I want to know is, is it ready? or still throwing engine faults frequently even after all the recent firmware updates and chip changes? I can live with continuous improvement via firmware updates, but dont want to be pulling the box apart to change out chips.
cheers.
Default 11-29-2018, 07:19 PM
Has been good with the latest chipset, so you should be good to go now.
wyld wyld is offline
Car: 2018 S5 Sportback
Default 11-29-2018, 07:26 PM
cheers.
With the latest chip and firmware update, I haven't seen any faults. Swapping the chip out took about 4 minutes so I wouldn't worry about that either.
2018 Audi S5 SB - Gotland/Rotor
Previous Cars █
2010 Audi A4 2.0TQ 6MT
2008 Audi TT 2.0T S-Line DSG
2005 VW Jetta GLI 1.8T 6MT
Car: Audi S4 B9
Default 11-29-2018, 07:45 PM
too easy. order placed
i am a bit of a novice at identifying the plugs in the engine bay though. is there a picture of the whole engine somewhere that has the approx location of each sensor? then the close up pics will probably make more sense.
Default 11-29-2018, 08:00 PM
George can update the install guide with a zoomed out photo if there isn't one already, should be!
Sq5_mk2 Sq5_mk2 is offline
Car: Audi SQ5 B9 (2018)
Default 12-04-2018, 07:02 AM
Hello everyone,
Now that I had a chance to use the JB4 on my 2018 SQ5 I have few questions that the community can help. I read this entire thread as well as some one the other sites and could use some more data or clarification.
Thanks in advance,
1. Will the drive mode both engine affects the performance with JB4? Would you get more power if you are running the same map in dynamic mode vs comfort.
2. Those the JB4 has any affect on shift points, would you have a quicker times if you run it in sports mode or manual vs drive.
3. Is using map 3 as a daily drive map not recommended, will that cause extra stress on engine components. ( I normally as other on this site used map 1. But today when driving to work 60 mph with ACC the instrument cluster shown 30 mpg 95% of the time for consumption. I know they are not that accurate but would you get better MPG in Map 3 and if so at what cost.
4. Anything else you change in your driving when running a JB4.
Thank you everyone for your thoughts or any links you can share to read more material on this subject. I’m admittedly new to tuners like the JB4.
Default 12-04-2018, 02:09 PM
Originally Posted by Sq5_mk2
Hello everyone,
Thanks in advance,
The JB4 adds power over what the ECU is requesting so the gains will be comparable in all the modes. The ECU uses throttle numbing in modes like comfort and with the JB4 also using throttle position as one of the parameters adding it might add slightly less in that mode.
The power drops of at high rpm so in that case the gear selected wont matter but the shift speed logic is different between D and M/S so it will shift gears faster.
Whatever extra stress is caused in a higher map will be insignificant in the long run if you maintain good driving habits when cold starting the car. 90% the oil is still cold.
On the cruise control this varies and I haven't tested it on these models. What happens on some cars the ACC uses quite a bit of pedal and it might be going into boost and off boost aggressively to maintain speed. If you got a Bluetooth you can monitor what its doing boost wise and compare to when you actually cruising with ACC off and see if there is a variance.
2021 VW Golf 8 R
Car: F06 N55 640i Gran Coupe
Default 12-04-2018, 04:51 PM
Looks like the wrong unit was shipped out, sorry about that. Email in and we will rectify it. On the RS3 test units the fuel plug is not used unless you intend to remove the manifold to fit it We working on a easier solution now.
If possible try get some pics of the OBD routing from inside please. We have a right hand drive RS3 and its slightly different.
Hey George,
Mine is also a RHD. Will get some pics of the OBD routing side & the whole installation process for you when we start installing on sat, I suppose the JB4 fuel sensor’s connection is for the LPFP? For the 2017+ RS3 8V.2, is it above the intake manifold or Below which required to remove the manifold?
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS DP n FULL Custom Exhaust
Custom BC forge 18/17 set up
Default 12-04-2018, 06:25 PM
Thanks for all the great tips.
In final when you just cruising at 60 mph for extended period 30 min and you want to get the best mpg at that stage what map you think would have the best possible result?
Default 12-04-2018, 07:23 PM
All the maps should be equal assuming you at constant throttle and just on boost to maintain the speed.
2021 VW Golf 8 R
