Engelhorn Engelhorn is offline
Car: 2013 BMW 750i
Cool 2014 750i Codes Limp Mode - 10-19-2021, 02:06 AM
I have been running my JB4 for over a year on my 2014 BMW 750i (N63TU engine). I keep it on MAP 2 for daily driving, motor has about 80,000 miles.
Yesterday she jumped into some type of limp mode running bad. The codes I'm getting is:
140010, 140610, 140001, 140601?
I replaced cylinder 6 coil, but didn't fix the problem, any suggestions?
Thanks, Ron.
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 10-19-2021, 07:24 AM
What did that number 6 plug look like?
Mike Levy
Car: 2013 BMW 750i
Cool 10-19-2021, 07:42 AM
I replaced the coil, but didn't pull the plug. Coil didn't fix it, I guess its time to pull the plug.
Default 10-19-2021, 12:28 PM
What were the descriptions for the codes? I'm assuming misfire? If so, that could be plugs, coils, or an injector. Swapping those components between cylinders until the problem follows will help you diagnose it.
Car: 2013 BMW 750i
Cool 11-01-2021, 12:57 PM
Plug was toast, dirty and wet, replaced plugs and she's back!!!
Car: 2013 BMW 750i
Default 11-04-2021, 09:17 AM
Well, number 6 fowled out again!!!
Plug looks wet. Not sure what is causing this????
Car: 2013 BMW 750i
Exclamation Replaced injectors - Do I need to code? - 11-20-2021, 02:53 AM
Okay, pulled old injectors #13647599876 and replaced with Bosch #0261500136KT.
Not sure if I need to code these new injectors, anyone know?
Mike_L's Avatar
Anti-Social
Default 11-21-2021, 05:47 PM
I know the N54 needs coding with INPA. Not sure on the N63. I would think it would.
Mike Levy
