(#1451)
sanjaycollins's Avatar
sanjaycollins sanjaycollins is offline
Car: 2021 Mazda3 2.5 Turbo AWD
Default Yesterday, 11:59 AM
That makes sense and I completely understand what you're saying. I'm fairly impressed with the performance of this car, having only mild bolt-ons and a piggyback, but I would also like to see what times could be achieved with an intercooler, charge pipes, a down pipe, a custom ECU tune and stickier tires.
JB4, CorkSport intake, CorkSport heat shield, CorkSport strut bar, CorkSport midpipe with resonator delete, CorkSport axle-back, CorkSport lowering springs, Continental ExtremeContact DWS06 Plus 215/45R18 tires and Avid.1 AV.20 18x8 +35 matte bronze wheels.
Default Yesterday, 12:05 PM
Originally Posted by SixPackABS
Good evening. What's the latest firmware version now?
The current stable version is JB4_P3_MAZDA_4_T4 and the current beta version is JB4_P3_MAZDA_5.
SixPackABS SixPackABS is offline
Car: Mazda 3 Turbo Hatchback (M3TH)
Default Yesterday, 02:36 PM
Is that the Firmware Version 3/4/5? What changes are their on the Beta 5?
M3TH user
TransModel = A Mazda but identifies itself as a BMW
danbfree's Avatar
danbfree danbfree is offline
Car: 2017 Golf TSi 1.8L
Default Yesterday, 05:18 PM
I will say that dang, there is so little room under the hood to get to anything, just looks so "busy" with a larger engine shoe-horned in there. I wonder if there will be much room to do bigger intercooler and charge pipes on the 3 when CorkSport does have some of these items for the CX-5 already. I know the turbo inlet pipe is coming out soon, and a DP is apparently on the way too. But it looks like Mazda has designed this in the 3 to run hot normally intentionally, which is just strange to me compared to previous cars. Oh well, I'm happy with how much the JB4 is indeed helping for now, I'll try to keep this thread a little more on-topic, and I'll try to see what kind of temps and times I can pull off with an ethanol mix now my car is "broken in" and have the air flow mods, that should be fun for now!
Mazda 3/CX-30 BETA tester BMS267264 - '22 Platinum Quartz Metallic M3TH - Performance mods: 235/40/18 on 18x8 wheels, strut tower brace, JB4, CorkSport Intake w/heatshield, CorkSport axle-back exhaust, waiting for mid-section on backorder.
Default Yesterday, 07:58 PM
"1) Adjusted TEMP_IAT logging channel to reflect charge temperature, post intercooler (I think).
2) Moved MAF air temperature over to ign6 channel.
3) Added pre intercooler charge air temperature under trans temp."
danbfree's Avatar
Default Yesterday, 09:45 PM
Yep, and I appreciate all the different readings as they really help tell the big picture!
Since 1. is easily the highest of the 3, I'm assuming it is actual intake manifold temp with hot EGR gases already mixed back in, to be clear. That is what I monitor live as one of the 6 gauges and the one I refer to as normally is allowed to get up to 120+, in fact I see 130 or so as "normal" and is the one I can now keep low, within 20 or so of ambient with normal driving until one good pull with my air flow mods that before would hit 110+ even in normal driving. It's my educated guess that I believe this is intentional by Mazda to help prevent carbon build up, help emissions and provide consistent performance. The ability to keep this lower does seem to result in higher performance, but so far air flow mods for the hood seem to help a lot only until the first big pull, then helps much less, but still some after this.
I'm now assuming that 3., pre-intercooler, under trans temp, is what the ECU determines at what point to open AGS/start IC H2O coolant circulation, I'll have to pay closer attention to that now too.
I'm happy to say that having an intake with/heatshield that uses stock snorkel feed that 2. stays within a few degrees of ambient. Since you have the same intake setup as me, I'm sure you would notice this as well if you check the logs or gauges under IGN6.
danbfree's Avatar
Default Today, 01:56 AM
Is anyone else not seeing this in the logs? Is this a gauge only option? It would be nice if this was logged so I could compare to the other two, which are indeed right in the logs. For the MAF temp that is listed under IGN6, just drop the decimal point to get the intake temp in F...
tymwalk tymwalk is offline
Car: 2021 Mazda CX-5 Turbo Carbon Edition
Default Today, 02:30 AM
Look at Temp_Trans for pre intercooler temperature on the 3.
danbfree's Avatar
Default Today, 04:44 AM
Right, but that was my question, it's not in the logs at all, must be a gauge option only thing...
Default Today, 05:32 AM
I can assure you it is in the logs. Change the graph settings to display the additional data.
danbfree's Avatar
Default Today, 08:51 AM
I don't use the graph function, it's much too small to view and manipulate on a phone very efficiently at all, it's a total pain. I have always exported the log as a spreadsheet. Now that I open the graph and see the settings I see there are a number items that are missing from the spreadsheet, that really sucks when it all should just be exported and included on the spreadsheet. I didn't pay all this money for a JB4 AND an app that doesn't export all the data, I guess I'm just gonna have to leave the app a bad review and maybe they will fix that. Not BMS fault, I know a 3rd party developer does the app, but this is BS. Out of all the data points there are only a handful not exported to the spreadsheet, I don't understand why they all can't just be exported.
Edit: OK, looks like it's called "transf" on the spreadsheet, and temp_water is called "waterf" on the spreadsheet. It's certainly not helpful and just confusing to have different names for the same thing between the graph and spreadsheet and only mention one of them when a spreadsheet is FAR easier to scroll through and use. That's why a more complete guide with all the terms and differences in names used between the graph and spreadsheet would be nice.
Default Today, 10:26 AM
Post your CSV as it should be there
Slow3 Slow3 is offline
Car: 21 Mazda 3 turbo awd
Default Today, 04:31 PM
Yep, all normal ECU safety reactions, when you see low numbers for Ign_2 it's not "full" knock, just small pre-ignitions the ECU picks up and it's good for those who don't know that modern ECU's are quite powerful and will save your engine from really poor fuel and/or too aggressive of settings. It's pretty damn hard to hurt your engine this way unless you use a tune or JB4 settings that bypasses the stock ECU safety settings, which you should never do anyway. From what you have shared, it sounds like a "full" knock happens at Ign_2 value of 20, so thanks for the detail to learn from.
That said, man, so sorry to hear that fuel is so poor in your area and e85/race gas cost so much! I thought it was bad that high quality "e88" here is $5.209/gallon, but I now will appreciate the decent fuel I can get!
I live in Florida Iím just using 93 octane no knocks so far on map6.
danbfree's Avatar
Default Today, 05:10 PM
I get it now, I guess most people use the graph and it's called "temp_trans" but I figured it out, by matching up numbers that it's called "transf" on the spreadsheet. It was just confusing at first when no one had mentioned the names were different between graph and spreadsheet.
danbfree's Avatar
Default Today, 05:14 PM
How far have you been able to push boost with legit 93? I know the defaults for map 6 are the same as what map 2 uses, I know I had a boost curve with a ramp up and down peaking at +6 in the mid to upper mid powerband when using an e25 mix, but that wasn't looking very closely at all the temps I should have and may not have been exactly very healthy!
Default Today, 05:43 PM
Today is the first day using it and itís set the way you have boost by rpm on page 57 or 58 canít remember
Havok Havok is offline
Car: 2021 Mazda3 Turbo AWD
Default Today, 06:05 PM
I have seen peak boost at 26psi. Thats absolutely maxed and only for a fraction of a second and have only seen it twice. Normally see 21-23psi
Default Today, 06:09 PM
Max so far is 22 psi on map6
danbfree's Avatar
Default Today, 06:41 PM
So, if you haven't changed any of the boost by RPM numbers that are in there by default for Map 6, then you are actually running exactly the same as Map 2, FYI, just so you know where you are starting from. If you have really good fuel you can try maybe making 2-3 of the upper-mid numbers that are 4 into 5's and see how that goes with only small numbers (well under 10) for IGN2 and see if you peak a little higher.
Default Today, 08:48 PM
I just took it for a little rip and it felt like I was getting boost cut or it was back off in power at higher rpm not sure whatís going on
Default Today, 09:21 PM
The car falls on its face after 5500 rpm. Most turbo engines fall off power band at a certain rpm. Ours does it a little too soon imo, but it is what it is. What you are feeling is normal what the car is at current time.... (one way around it is to switch to manual mode, shift right when you get to 5400, that will keep you in peak hp range) Hopefully DramaTuned releases full ecu tunes for the car sooner than later...
