(#51)
zse8h zse8h is offline
Car: M5501
Default 07-12-2022, 12:21 PM
Dude, you're a hater. Go back to harassing about BCM connections. Do you have a Dyno? Bet not? I'm fast than you just accept it.
2021 M550i
Bernina Grey Amber Effect
BMS Elite Intakes
Active Autowerke High Flow DwnPips
JB4 Map 1
Retired:
2009 335xi
Completely Moded out
Antec800 Antec800 is offline
Car: 340ix
Default 07-12-2022, 12:33 PM
Are you a kid or a man child lol? Never once harassed anyone about any bcm connections, and also I just posted my draggy times which clearly was faster then your times , and a Dyno graph doesnít prove anything since there are many different types of dynos which means the same car on 2 different dynos can have 100 more hp or a 100 less, and also the parameters set by the operator can heavily influence the numbers as well the gear
Car: M5501
Default 07-12-2022, 01:16 PM
I don't trust draggy could be anyone's...where is your Dyno? Don't have one? Oh I'm faster. Loser. Lol
2021 M550i
BMS Elite Intakes
JB4 Map 1
Retired:
2009 335xi
Car: 340ix
Default 07-12-2022, 02:28 PM
You donít trust dragy or you donít trust me? Why would I post someone elseís results my times arenít that spectacular https://www.kapwing.com/videos/62cde74cc01e4800cdc59ea5 anymore name calling?
Car: M5501
Default 07-13-2022, 12:33 AM
I'm just messing around. I here you on the 5.2 but anything below 3k rpm I am worried about transmission slip. GPower is concerned about this in relationships to piggybacks vs ECU remaps that can tailor delivery of all the extra power. I don't launch so maybe 4 psi up until 2.5rpm and then 5 from there? Il test this and see what happens. I changed from kph to mph so Il check this out also. Sense your running E30 mix i need 102 octane.
2021 M550i
BMS Elite Intakes
JB4 Map 1
Retired:
2009 335xi
Car: 340ix
Default 07-13-2022, 12:51 AM
Haha im glad I didnít make a enemy I wasnít trying to come off rude, and for the transmission not taking the power I think in the 2020+ the transmission was updated so I wouldnít worry about it especially if your under 70k miles, I was actually impressed with your map 1 results, map 1 for me was not that quick
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2022 X3 M40i
Default 07-13-2022, 03:32 AM
Don’t worry about the transmission. It’s the same 8HP76 that’s used in the M5. Though it’s only rated for 760nm (560ft/lbs), it’s been shown to hold upwards of 1000ft/lbs without issue.
Mike Levy
2022 Black Sapphire X3 M40i
phaser's Avatar
phaser phaser is offline
Car: X5 M50i
Default 07-13-2022, 08:04 AM
Originally Posted by Mike_L
Donít worry about the transmission. Itís the same 8HP76 thatís used in the M5. Though itís only rated for 760nm (560ft/lbs), itís been shown to hold upwards of 1000ft/lbs without issue.
Thank You for sharing this important information about the transmission.
Do you happen to know if the same is true for the transmission in the current X3M/X4M. Could it even be the identical unit?
Mike_L's Avatar
Anti-Social
Car: 2022 X3 M40i
Default 07-13-2022, 11:47 AM
Its the same 8HP76X, but the bellhousing is different, so the part number is too. The B58/S58 have their timing components at the back of the engine, so their belllhousings are unique.
Mike Levy
phaser's Avatar
Car: X5 M50i
Default 07-13-2022, 12:35 PM
Interesting. Good information.
Car: M550i
Default 07-14-2022, 07:55 AM
For 100-200 glory times it's best to wait for colder temps and lower DA. I haven't done a dedicated 100-200 with the car in its current configuration bit I recall getting the best times in February using manual and shifting before redline. That was in the 6.7-6.8 range if I recall correctly.
phaser's Avatar
Car: X5 M50i
Default 07-14-2022, 10:07 AM
Damn Dude, those are crazy fast 100-200km/hr times.
A Ferrari F40 is 7.1 and a C7 ZR1 is 6.9.
Are you doing this on Map1?
Car: M550i
Default 07-14-2022, 10:45 AM
+5psi using half tank 94 pump fuel and 75ml of boostine. I think I can beat that now with lighter wheels and tyres. Search Boostedsix on dragy.
phaser's Avatar
Car: X5 M50i
Default 07-14-2022, 11:42 AM
Will do. Keep up the good work, look forward to your updates, great stuff.
