rossco99 rossco99 is offline
Car: Mk7.5 Golf R
Icon1 Golf R Mk7.5 - Map2 e30 Logs - 01-12-2020, 08:20 AM
I did a before and after pull using map 2 on two very hot days.
15 litres (4 gallons) of e85 mixed to a straight 98 tank filled up.
32 - 35 degrees Celsius outside (95 degrees Fahrenheit)
98
***********/u/rossco99/golf-r-jb4-map2-0?log=0&data=1-4-11-23
e30
***********/u/rossco99/golf-r-jb4-map2?log=0&data=1-4-8-11-14-23
^^ these are datazap links
In my non expert view, timing really improved but the fuel trims went over 40%, currently I'm on FOL 45 so I'll try 50 next.
Default 01-12-2020, 10:10 AM
98
e30
We dont use datazap so best to attach logs. Trims are fine to be high as longs as the AFR is staying steady. On the 7.5 stay on 45 FOL, going higher will cause fuel rail pressure faults now and hten.
Car: Mk7.5 Golf R
Icon1 01-12-2020, 09:11 PM
JB4 Logs Attached
Seems a bit lean to me around 3500rpm at 14 then it comes down to 13 - 13.5 3800rpm onwards.
Default 01-13-2020, 05:33 AM
JB4 Logs Attached
Logs look good. On low rpm ECU will lean out mixture for maximum spool to decrease the lag of the car.
On the E30 you can go to map 3.
Car: Mk7.5 Golf R
Default 01-19-2020, 04:27 AM
I did three back to back pulls on Map3 today, 27 Degrees Celsius (80 Degrees Fahrenheit)
Still on my same e30 blend
I think things are looking good.
Nora2004 Nora2004 is offline
Car: 2017 Seat Leon Cupra 300
Default 01-19-2020, 06:34 AM
God damn I wish we had access to E85 in the UK!
Your logs look great, still got plenty of room left for more boot too, crank her up and make the most of that corn!
Default 01-19-2020, 07:59 AM
Looks fantastic.
Car: Mk7.5 Golf R
Arrow 03-07-2020, 08:53 AM
Update from me and my e30 adventures:
I went to the drags this week and managed a 12.406 with a Map6 built from a slightly upped Map3 Base.
I also managed a 12.442 with a straight Map3
Both logs are attached.. I should say that my mix was more of a e20 than my typical e30 blend.
One of my challenges is the launch control delay.. needed to release the brake at the second light for the 12.406
The other is the timing fall off cliff at gear change, really feels laggy on shifting.. seems to be fine if I manually shift at 5500
Car: Mk7.5 Golf R
Default 03-07-2020, 08:56 AM
Here is my Map 6:
1500 - 0.0
2000 - 2.0
2500 - 3.0
3000 - 3.0
3500 - 3.5
4000 - 4.5
4500 - 5.5
5000 - 6.5
5500 - 7.0
6000 - 7.0
6500 - 6.0
7000 - 6.0
julian2292 julian2292 is offline
Car: bmw 1m
Default 05-15-2020, 06:14 PM
Hi!
what other mods you have on your car..
down pipe and intake??
Car: Mk7.5 Golf R
Default 05-15-2020, 06:17 PM
Just intake elbow and using e30
Car: bmw 1m
Default 05-15-2020, 07:09 PM
Wow!
With down'pipe and intake you can make high 11s.
Thanks for the info.
I am trying e30 next week.
