DoobiieDripp's Avatar
DoobiieDripp DoobiieDripp is offline
Car: 2010 BMW 535i
Default 29E0 - Fuel Mixture Control - 11-15-2017, 09:42 PM
Hey guys, I've been dealing with a lot of issues with this car and quite frankly I just want the to be over. With that being said, the issue at hand is this code. 29E0 - Fuel Mixture Control. I've done a Google search that got me nowhere and I'm wondering if anybody has an cure for this code. The car is a 2010 E92 335. My symptoms are a rough idle, lack of power, and it's shut off twice. The rough idle feels like it's about to misfire but never does. What I've changed recently is, oil, OFHG, valve cover gasket, water pump, coolant, all 6 spark plugs, bank 1 pre *** o2 sensor, and cylinder 5 coil. Any info helps.
Thanks in advance.
2010 535i Stock -
2010 E92 335i JB4 - DCI - Active Autowerkes Charge pipe & BOV - 19" Verde Staggered Rims
www.blacktiedetailingco.com
IG - @BlackTieDetailing
Black Tie Detailing
Car: 2010 BMW 535i
Default 11-15-2017, 09:48 PM
Here's some logs from last night. Hopefully they help.
2010 535i Stock -
Black Tie Detailing
Default 11-15-2017, 10:05 PM
This code can be pesky & hard to track down.
When is the idle rough? On cold start, or all the time,
Car: 2010 BMW 535i
Default 11-15-2017, 11:09 PM
It's rough all the time. No matter if it's cold or fully warmed up.
2010 535i Stock -
Black Tie Detailing
Loskop Loskop is offline
Car: BMW 335i N54
Default 12-25-2017, 02:26 PM
Did you manage to find the cause of the fault?
Default 12-25-2017, 11:41 PM
My money is on Injectors
Default 12-27-2017, 02:02 PM
If you are getting 29E0 and not getting 29E1, then that is generally a hardware issue as Dave stated. Injector, O2 sensor, etc. Did you reset adaptions after replacing the O2 sensor?
