I installed my Jb4 in my new 335i two days ago and right off the back in Map 5 and Map 1 I get a misfire in Cylinder 1 if I go WOT, I'm constantly getting the Boost over target & Low Boost Mode Codes. Checked my user adjustments to make sure they were set to default and they were. I took a couple of logs the best I could. I'll attach them. Also I noticed that in map 0 I'm boosting to 20psi and I know thats not good. If anyone could help me figure out what's wrong that would be great. Anyone know if this issue could be because I worked something wrong? I double check everything after install but maybe I still missed something.
It's a tad bit difficult to get a WOT log because as soon as I floor it the car misfires. But I logged what I could and attached it. As far as menu 11 and 12 I think they're set to default. And to troubleshoot cylinder 1 I would swap spark plug or coil with others to see if the misfire changes cylinders correct?
So Menu 11 was at 1k Rpm and I changed it to 0. Menu 12 was at 3k Rpm and I changed that to 2400 RPM as recommended. I'm no longer boosting to 20psi in Map 0 but still misfiring. ILloyd check the hardware today since I'll have some time.
