(#4651)
vietnameeh vietnameeh is offline
Car: Q50
Default 10-10-2019, 08:54 AM
Thanks guys! should I taper down to say 4 at 6k? or even lower?
2019 Q50 Luxe
JB4 + Fuel Wires
91 Octane
jrobohm's Avatar
jrobohm jrobohm is offline
Default 10-10-2019, 04:39 PM
The logs with a less aggressive boost add at high RPM will tell the tail. Remember you can use number between whole numbers. Your 91 pump fuel will be an ongoing limiter to more boost unless you add E85, octane booster, or go WMI.
2017 Q50 Premium RWD
  • BMS JB4 w/ Fuel Wires
  • BMS CAI w/ Inlets
  • BMS WMI w/ PM8ís
  • AMS HE w/ Aux Tank
  • AMS LDP
  • FI Res CBE
  • Mishimoto Oil Catch Can
Silversport22 Silversport22 is offline
Car: Q50
Default 10-11-2019, 05:04 AM
So I decided to not go the jb1 route and just go 4 as I can pick one up used from a friend. Is it ok to just go with JB4 without any logging (no data cable or bluetooth). I would leave at the default map of +4 until I decided on either the bluetooth or data cable down the road. Its a silversport so I assume that +4 with 93 octane should be safe without logging for now.
Also, i have heard of connection issues with the bluetooth when buying used and having to have the "user" reset through BMS. Is this still the case?
Default 10-11-2019, 01:43 PM
You can use it on map 1, no problem without logs.
Yes, if you purchase the BT used and the previous owner did not unlink. You'll have to screenshot and email to the email requested on the screen when trying to connect.
Sean the Mick Sean the Mick is offline
Car: Q60
Default Yesterday, 08:20 AM
Hey peepers... looking for opinions and to get schooled as I am a TOTAL JB4 noob...
Sooo...
2018 Q60 Sport (NOT RED SPORT) AWD w/ BBE catback and Fast Intentions LDP installed with JB4 and 94 Octane...
Is Map 7 not the best idea to constantly select? Too much stress?
I do spirited driving and some highway driving, enjoy the WOT when I get the chance...
Thanks and Cheers!
