(#1676)
harizbbjt harizbbjt is offline
Car: Bmw F10 520i
Default 10-12-2018, 05:41 PM
Does it happen on map 0?
yes it does but when I disconnect the jb4 everything is fine.
vkiyko vkiyko is offline
Car: BMW F30 328I 2012
Default 10-16-2018, 03:32 AM
I have the POSI-TAP connectors JB4 N20
my friend have updated my JB4 to the OBD version of firmware. Now I cant use my JB4 properly.
I can't read logs neither on PC nor via Bluetooth.
Where can I get an older version ? for JB4 without OBDII
Default 10-16-2018, 07:45 AM
You can't. You'll need to convert it to new OBD style. You can find it here:
http://www.burgertuning.com/JB4_upgrades.html
It will be labeled as :
OBDII CABLE WITH JB4 SIDE CONNECTOR FOR RETROFIT
Default 10-16-2018, 07:47 AM
Can you email me, it will be easier to help you on this.
Payam@burgertuning.com
Default 10-16-2018, 07:50 AM
Thank you for the prompt reply.
However, I am Located in Russia. Delivery would take around a month.
Is there any other way of reconnection of existing wires for my JB4 to work?
notebookboy's Avatar
notebookboy notebookboy is offline
Car: 2013 Z4 20i
Default 10-27-2018, 07:48 PM
Hello BMS Team,
Just upgraded to N20_JB4_X1_Z4_2.hex on my Z4 E89 2.0T. And noticed that gauge sweep was disable. Checked for the other threads that it was move to steering menu 5/8 or 6/8. However, the max number on rpm is 7 on Z4. Any idea on how to enable the gauge sweep please?
Default 11-04-2018, 07:02 PM
It has it's own wheel control guide, should be in the current install manual for the N20 towards the bottom.
528n20 528n20 is offline
Car: 2015 528i
Default 11-05-2018, 11:40 PM
Originally Posted by bhom920
Just happened again. Here is a video of what it does https://youtu.be/6V0_9phU2Ps It almost seems like it wants to go into menu system and is showing that its on menu 0, Map 1. Is there a way to disable this menu option if it doesn't work with the x3?
Any update from Terry? Same happened to me again this Monday
Furbz Furbz is offline
Car: Bmw 320i F30
Default 11-09-2018, 01:40 AM
Just a thank you.
5 years with my 520i and JB4 +-65000km
pulled the chip out for each service.
map 5 always.
BMW service plan on the car has now run out. and so far in that time nothing has gone wrong.
Thanks Burger tuning for the great product
Default 11-09-2018, 10:57 AM
Originally Posted by Furbz
Just a thank you.
map 5 always.
This is awesome. Thank you for your continued support!
