Guapped Guapped is offline
Car: 07 335i
Default E30 Log Review - 08-01-2020, 12:26 PM
I am FBO with 5gals of e85 and 11 gallons of 92. The gas station says ethanol content wont be below 70%, and the 92 wont be above 10% but I have not tested ethanol content. My car has JB4 with mhd bef for pump gas. I ran the car in map 5, and a little in map 2. Curious how my logs look, from what I can tell lpfp, and hpfp are doing fine. I think I may have a issue with trims? There are multiple logs in the one file, and map two logs are at the end. Thank you in advance for any advice it is much appreciated!
07 335i M/T FBO
Default 08-01-2020, 03:54 PM
LPFP is in the 40s I’d replace asap or run no ethanol until you can.
