(#326)
JonnyB JonnyB is offline
Car: 2017 Q60 RS400 AWD
Default 07-09-2020, 08:06 AM
If you need to reach me directly quickly email is usually the best way, I only get to forum threads after I've cleared my email box and lately I've been having a hard time clearing it!
Log looks fine though. You're not going to blow anything up running less duty bias, and probably not running more duty bias, so adjust until you get the feeling you're looking for behind the wheel.
Thanks Terry! I'm still tweaking things up but the car feels completely different, with a crazy amount of power down low, i just lost a bit of traction (with traction control on!) yesterday from a 2nd year - which is insane considering I have PS 4S's and they were warm. Just amazing.
The one thing I'm worried it about that "clunk" noise I heard once when downshifting. Considering I still have stock exhaust, besides not pushing boost much, is there something else I should be aware of / keep a more conservative setting - specifically anything EWG related?
Thanks so much for getting back to me!
2017 Q60 Red Sport AWD Obsidian Black / ProActive + Tech Package / Weathertech Q60 Mats / Michelin PS 4S / Nokian Hakkapeliita R3 / 18' RWC IF395 Anthracite (winter) / BMS Elite HE / JB4 + Bluetooth + FW (not installed) + EWG / Chrome Delete Front Grill / CF Duckbill RR Spoiler (not installed) / Add OCC (ordered) / RSR Down Springs / FI HF FDP (ordered) / FI CBE (ordered)
Default 07-09-2020, 08:32 AM
The kick in the pants response is what I like most about the new EWG control. And as our early dyno showed once we augment the fuel control a little there is certainly more power to be had also going forward.
In terms of the clunk lowering PID gain might reduce response and thus reduce it? I haven't noticed anything with ours on downshifts.
Default JB4 Switching automatically from map 6 to 1? - 07-09-2020, 12:32 PM
Hey Terry
Thanks again for following up on my previous post. Today I managed to log a strange thing that is happening: car starts beeping (same noise when switching maps) and in JB4 it shows that it automatically switched from map 6 into map 1 by it self. It happened 3 times just this afternoon and I was managed to get logs rolling when this happened, please see attached.
It was a very hot day and I wasn't going WOT, I was driving actually rather quite slowly on a school zone. Any thoughts?
PS: I only started having this problem after installing the EWG wires.
iamafrayedknot's Avatar
iamafrayedknot iamafrayedknot is offline
Car: 2019 Q50 Red Sport AWD
Default 07-09-2020, 03:47 PM
Hey JonnyB - grab the latest BETA version of firmware (version 9)
or alternatively the Beta JB4 app (A333)
Josh
2019 Q50S AWD
Default 07-10-2020, 07:08 AM
Originally Posted by dajcopeland
Hey red sport guys. What duty bias settings are you having success with? Iím still trying to fine tune mine and getting oscillation around 3500 to 4000. I am currently set at 50 until 3000 then I go up to 55 until 4500 and then 60 through 7000. Iíve tried several other combinations with similar results.
Hey there - 2017 RS here, had the same oscillation issue. A fellow member (iamafrayedknot) mention he had the same issue as well and fixed it by reducing the duty bias to 35 below 4k rpm, i.e. like this:
1500 - 35
2000 - 35
2500 - 35
3000 - 35
3500 - 35
4000 - 40
4500 - 45
Can u give it a try and let us know?
Default 07-10-2020, 07:12 AM
Oh right on, will give it a try today. Thanks!
guitaristguy313 guitaristguy313 is offline
Car: 2020 Infiniti Q50
Default Better Launch - 07-15-2020, 06:46 PM
Hey Guys. Looking to improve the launch on the car. Have an AWD 2020 Luxe. Was hoping the EWG would help with the turbo lag. Attached is a log with the traction control off and brake boosting. This felt worse then just punching it. Any suggestions on what I should change to get more get up and go from a dig?
dajcopeland dajcopeland is offline
JB4
Car: Q60 Redsport
Default 07-17-2020, 02:00 PM
1500 - 35
2000 - 35
2500 - 35
3000 - 35
3500 - 35
4000 - 40
4500 - 45
I tried reducing duty bias to 45 below 3500 rpm and my car ran like dog crap and even backfired. I'm going back to 50 where I have the occasional oscillation problems. Still trying to figure this out.
Q50_99 Q50_99 is offline
Car: Q50RS2017
Default 07-20-2020, 08:04 AM
Hi terry
Please Can you check the log after changing map6 and adding EWG with fuel wire
I feel Little lag some time during shifting
Red sport RWD with CBE + HE + Ewg&fw + ldp + AMS intake
Fuel 91+
I used normal settings for red sport
Peekb24 Peekb24 is offline
Car: Q60 Red Sport 400
Default 08-01-2020, 10:50 AM
I own a 2017 Q60 RS 400 and I’ve done a lot of research but I can’t find much information on using the Bit6: option. Does anyone have any experience with using it? I’m under the impression it has something to do with DME_BT I’ve noticed the values change when it’s on
I’ve done a few logs with it on and the car feels better with it on but that’s all I can really say.
Car: Infiniti Q50 RS400
Default 08-01-2020, 10:59 AM
Originally Posted by Peekb24
I own a 2017 Q60 RS 400 and Iíve done a lot of research but I canít find much information on using the Bit6: option. Does anyone have any experience with using it? Iím under the impression it has something to do with DME_BT Iíve noticed the values change when itís on
Iíve done a few logs with it on and the car feels better with it on but thatís all I can really say.
Bit 6 ON for RS. I donít know the effect on it for nonRS.
2020 Q50 RS AWD
AEM 50-1200 LPFP
AMS/Infiniti CAI housing
BMS EWG wires
BMS intake inlets
BMS JB4 w/Bt
BMS fuel wires
BMS WMI kit
Custom 2.5in catback exhaust w/res
CZP LDP w/heat wrap
DevilsOwn 2.25gal WMI tank
Infiniti Sports Mufflers
Inline dual OEM/dual pass hx
Stillen RSB
Swift lowering springs
Z1 Motorsports 2 piece rotors front/rear
Z1 Motorsports subframe collars
Default 08-01-2020, 11:02 AM
Yea I turned it on and it has less boost lag but Iím just trying to make sure I ainít breaking nothing lol. Have you tired it ?
Default 08-01-2020, 11:11 AM
Yeah, Iíve always had it ON since I have an RS.
2020 Q50 RS AWD
AEM 50-1200 LPFP
BMS EWG wires
BMS intake inlets
BMS JB4 w/Bt
BMS fuel wires
BMS WMI kit
CZP LDP w/heat wrap
Stillen RSB
Default 08-01-2020, 11:14 AM
Yeah, I’ve always had it ON since I have an RS.
Nice I’m probably gonna add FW and the EWG wires what’s your take on those on 93 octane I’m never gonna run E
Default 08-01-2020, 11:20 AM
Nice Iím probably gonna as FW and the EWG wires whatís your take on those on 93 octane Iím never gonna run E
Iíve always recommended using the JB4 and fw together when someone asks me to get that afr a bit controlled at wot. And Iím always on 91octane, havenít used e30 in a while but logs looked good regardless of pump or mix.
2020 Q50 RS AWD
AEM 50-1200 LPFP
BMS EWG wires
BMS intake inlets
BMS JB4 w/Bt
BMS fuel wires
BMS WMI kit
CZP LDP w/heat wrap
Stillen RSB
Default 08-01-2020, 11:22 AM
Gotcha appreciate it man!
Default 08-01-2020, 11:25 AM
No problem. Go meth next lol.
2020 Q50 RS AWD
AEM 50-1200 LPFP
BMS EWG wires
BMS intake inlets
BMS JB4 w/Bt
BMS fuel wires
BMS WMI kit
CZP LDP w/heat wrap
Stillen RSB
Default 08-01-2020, 11:38 AM
Iíve considered it but Iím just getting started lol
azsuptt azsuptt is offline
Car: Q50RS400
Default JB4 Connectors Question - 08-25-2020, 01:47 PM
Seems from picture the egw connectors will plug right under turbos. However mine came with an Extra wired (Two Black with red connectors shown in pictures), The instructions above do not mention this setup. Wonder weather they are Fuel wires and where do they need to be connected or if they even need to be connected. See image below of my setup (First Image are the connectors in question)
Name:  jb4 egw connectors3.jpg
Name:  jb4 eww conn 2.jpg
Name:  jb4 egw connectors.jpg
I search but no video of installation on these egw with fuel wires so if you have one please post it
Default 08-25-2020, 02:28 PM
Fuel wires are covered in the main JB4 thread/post.
Car: Q50RS400
Default Egg and fuel wires - 08-25-2020, 06:28 PM
In the fuel wire thread there is no picture with my setup above these two black wires are only about feet long and part of the egw connectors as shown in pict 1 where do they go if they come with the egw connectors hardness. I read the fuel wires thread and they reference a long and short with a resistor. Different than the one shown in my picture
Car: Q50RS400
Question Need help identifying wire location - 08-25-2020, 07:35 PM
I being reading all post and none shows the wires shown on my jb4 setup, also downloaded the instal guide with no luck either. Being back and forward between the forum and page with no luck
Can someone tell me where these black wires with red connectors go .
Are these fuel wires??
Car: Q50RS400
Default JB4 Connectors Question - 08-26-2020, 06:14 PM
Will post on Main Page or Fuel Thread
Danny705 Danny705 is offline
Default Just installed EWG wires - 08-31-2020, 06:04 PM
Okay I just installed the EWG wires I set all the parameters to the default setting as per JB4
2019 q50 RS with fuel and EWG wires running map 6
Settings:
duty bias all 50
pid 20
auto shift 60
ff 50
Could anyone tell me how my logs look
Default 08-31-2020, 06:07 PM
Settings:
duty bias all 50
pid 20
auto shift 60
ff 50
What number should the default wastegate position be set to??
By default my JB4 has it listed at 0 should I leave it that?
